Power Button
I am thinking a 93 does not have this 2nd start button
Correct...your 93 is not equiped with the "start in second" button.
One thing to try in low range (with the pin 7 mod) to stop the hard shifting is to turn off the power button, letting your tranny climb to second at a lower RPM
I never turn on the power button unless I am getting on a highway. I think I will be playing with it now.
Don't be shy
This is a little bit of an off-topic post, but all of the sudden my switch doesn't work. It has for years and now it won't stay on in the PWR position and the light doesn't come on in the instrument cluster. Has anyone had any experience with this? My first instinct is that's it's simply a worn out switch, but I don't want to order a new one just on a guess if there's a way to test the switch.
Did you spill your Coke on it from the fabulous cupholder? I know mine is usually stuck due to the sugar, coffee, Gatorade, pie filling that spills on it while using the brakes excessively while in traffic and spilling every drink on it. You can take it out, disassemble and clean with electrical contact cleaner. May help. Or buy a new switch.
I tracked mine down to.po had at one point taken out console to hook up a stereo and left the switch unhooked.plugged back up for that little extra zip, cause they are dogs without the button.
