- Thread starter
- #81
EGT probe installed.
Some part numbers
51421-60140 right frame mount
51422-70140 left frame mount
12311-17020 right engine mount
12315-17020 left engine mount
12361-17020 rubber motor mount (two needed)
Hehehe. Good catch! EGT!EGR or EGT?
Dunno squat about diesels, in my own defense.
All of those parts are accessible in the US except for the to engine rubber isolators.
I am using the new hz rubber mounts 12361-17091 which ARE US part numbers. later version in my mind is better. DO not get aftermarket mounts, they all fall apart too quickly.
Everything moves around a bit, Chris, at least my 80 did, offroad, in reverse, and under acceleration.
How are the front and rear drivelines looking for length and angles?
Edited: Unsolicited advice, but it'd be worth checking the pinion angles BEFORE going crazy on cross member fab or cutting the body.
Thinking it might he worth it to check out now, when possible to pitch the transfer case in crossmember construction, since it may be beneficial to drop the rear.
Hate being a naysayer and I hope I'm wrong, but don't see how this is gonna work full time, within the shorter OAL, without funky double cardan (or worse, double, double cardan shafts) with the LP front diff.
May be able to source another HF1A mechanical case, if you're interested.
Know they have several, all still attached to H15Xs, but have one H151 that I was going to ask they remove the HF1A, for shipping considerations.
I would have removed the turbo to drill the hole for the EGT probe. Any worry about metal shavings falling down inside when drilling for the probe?
This is what in my mind.![]()
