Poll on total brake failure in 100 series
Has your 100 series LC experienced total -or near total- brake failure?
  • No.
    Votes: 1,357 72.6%
  • Yes. My truck had between 0 and 50k miles at the time.
    Votes: 1 0.1%
  • Yes. My truck had between 50k and 100K at the time.
    Votes: 17 0.9%
  • Yes. My truck had between 100K and 150k at the time.
    Votes: 79 4.2%
  • Yes. My truck had between 150k and 200k at the time.
    Votes: 152 8.1%
  • Yes. My truck had between 200k and 250K at the time.
    Votes: 155 8.3%
  • Yes. My truck had between 250k and 300k at the time.
    Votes: 90 4.8%
  • Yes, My truck had over 300k at the time.
    Votes: 46 2.5%
  • Total voters
    1,869
Hello Forum,
2003 LX470 w/ 135k miles.
Kid on a scooter scooted out in front of me.
Slammed on the brakes.
SUV stopped just fine.
Kid is fine.
Most likely crapped his pants.
Pretty confident he'll remember the incident and look both ways before scooting across the road.
Less than a mile later, approached a stop light going around 25 MPH, went to hit the brakes for the 1st time after the emergency stop, and the pedal went more or less to the floor.
Used the emergency brake and pulled off to the side of the road.
No dash lights.
Popped hood and found brake fluid slowly leaking from the bottom of the brake booster / master cylinder assembly.
No dash lights appeared until the brake fluid level was officially "low" from the slow leak.
Only DTC is C1202 (Low Brake Fluid).
I'm guessing I've blown a seal out of the assembly.
Anyone encounter this before?
I'm pretty confident that the rebuild kit (04493-60330) will not help me, correct?
I believe it just includes the plunger and seals and the assembly would not leak if one of those seals failed (it would leak internally, not externally...).
I read about Andy Le doing rebuilds and I've reached out to him.
Any thoughts are greatly appreciated.
Thank you.
Tom
Hello Forum,
Kid is fine.
No dash lights.
Thank you.
Tom
They pricing is so good on the new units you need to just buy new.
No but proactively replaced the booster and masster cylinder at 320,000 miles.
There is a 20% off + Free Shipping (over $75) sale going on right now.
^^THIS^^ They're not cheap, but considering the price of a whole "contraption" has come down from around $3,000 to about $1,500, the price for that peace of mind IS cheap.
Hello Forum,
Kid is fine.
No dash lights.
Have you ever heard, the brake low pressure alarm?
We can test/activate the alarm, to see if working. By: IG key on, pump brake pedal rapidly. In a new booster ASSY w/ brake master, takes ~30 pumps to set off alarm. In old weak system, ~10 pumps.
If fluid gets to low, we can get air in to master and brake lines. Pedal will go low.
Some have seen leaks form one or more of the grommets, at bottom of reservoir. I have not seen these leak.
I have seen leaks form:
ABS unit (black box on side of master). Typically set off get brake alarm.
Weep hole at bottom of pump. This happens if booster motor breather gets clogged.. Motor will then, suck fluid from pump.
If booster motor is working. Test:
IG key OFF. Pump brake pedal 40 times. See level in reservoir raise. Turn IG key ON. Hear brake booster motor run. Time how long it runs. Battery at 12.5V 30 to 40 seconds.
If leaking at plunger (seal kit). Leak would be in foot well. Not in engine bay.
Thank you.
Tom
Remain master. Are a bad idea.
99 LX, 236k, no brake issues other than replacing rear pads & rotors at 86k.
Since the wife handed the vehicle to me after that, no more brake issues. Front pads/rotors still original factory parts, never replaced.
I intentionally drive this vehicle gently to minimize drivetrain stresses, including brakes. That means lighter acceleration, lower and more constant speeds, and slowing down more gradually where possible to reduce brake use and peak braking forces. One reason is that I saw the unbelievably overcomplicated brake master cylinder & booster system when I bought it new.
A new booster assembly lists for $2k. Rebuilding it yourself will be extraordinarily time consuming and prone to problems, and the result will not last as long as a new assembly.
The booster pump on this vehicle operates normally at startup. I am disinclined to periodically stress-test that system at startup as advised by some posters here - the more it is used/stressed the sooner it will fail.
Philosophical notes:
Automakers have mostly lost the K.I.S.S. view. This brake system could have been made much simpler even with ABS. But even ABS is dubious - before ABS, developing braking skill under all conditions was a point of pride and a competent alert driver anticipating braking situations didn't need ABS, but as the nanny state grew ABS and other "safety" hand-holding have made the masses even more incompetent and dependent on the hand-holding. Its reaching new levels now with the plethora of "driver assistance" overcomplications in new vehicles.
Few Americans understand the sound basis of my driving style to minimize wear and tear in order to maximize vehicle reliability and life while minimizing overall cost. All they see is a vehicle moving slower than they can stand in their knee-jerk impatience, they don't think about the fact that the few minutes difference in cross-town trip time has a negligible impact on the day, and they have no idea about engine/trans stresses increasing proportional to the square of rpm and high cycle fatigue vs. peak stresses, thermal shock and cycling effects, or brake wear correlated to pressures and pad/rotor temperatures. (See above about mass incompetence.)
  • Like
Reactions: uHu
My dash lit up like a Christmas tree, constant. I was 400+ miles from home. Drove the car to nearest city, lights turned off then back on again. I had to freight my car back home, going to hitch a ride back home. Theres no way I was going to drive my car back home like that. This really blows. But im glad my car is going home, now my turn
A few data points.
My 05 LX470 @ 215k, perfectly fine, all original.
My 05 LC @ 225k, lost the booster.
The LX is a nice rust free 100 from out west. The LC is a rotted to death local example. It has had all it's brake lines "replaced", and I suspect the booster failed from the typical wrong brake fluid usage.
I would do this repair on the side of the road. It's doable with just a few hand tools and and pole to depress the brakes when bleeding.
On the other end of the spectrum here but.....
2000 LX with 505k miles and zero issues with ABS and braking system. All original. And brake fluid has been changed only once, at around 500k, since I first got it at 43k miles.
It's the 2000, with type A pressure sensor.
Quick question, I have that exact model year, production/assembly date of the vehicle is December 1999. Since it is no longer available, can I use a different model year as a replacement? My brake master assy is doing fine so far, but at 225k miles it's definitely something that I wouldn't mind replacing in advance before permanent failure.
Short answer, no! 98-99 have one brake line to rear. 2000-up, have two rear brake lines. Good news: I show Toyota still has, the 98-99 booster w/master AASY. (the whole deal).
LC 1998 booster fail back in 2007 with 110k miles on it. My dashboard turned into a Christmas tree lighting extravaganza - no brakes. Figured I would attach email I received from Luis (met through IH8MUD) - big help. Step-by-step instructions for anyone that wants to do it themselves.
Does changing the brake fluid every 2-3 years actually help extend the life of the brake booster/master cylinder on the 100 Series?
Just curious because there are quite a few examples in this thread of 100s/LXs going 200k–500k+ miles with the original braking system, despite the brake fluid being changed very infrequently.
Or is booster failure mostly unrelated to the age/condition of the fluid?
Yes. Once factory fluid is either altered with adding any fluid. It then effects master/ABS unit and caliper piston seals. But even if never altered, in time it too will build up matter. Which is a result of brake fluid hygroscopic nature. One can test for water content and flush as needed. Which in the arid climate of Denver. We can get 10 years, maybe more on factory fill.
Factory install fluid is the best we'll ever have. It can not be imported into USA in bottles. But the Toyota bottles, are the closes to factory fluid we can get.
Booster motor or accumulator failure, has little to do with fluid condition. Fluid condition could have effect on pump, but we don't really see pumps fail.
Bad fluid is hard on seals. It also builds up matter, that clogs screens. We've screens in reservoir and in ABS unit also. See:
