points?
Little Rock, Arkansas
I have looked in the tech section and did a search, but my ??'s were not answered. First, what are points? Second, is this a worthy project to upgrade? I guess that upgrade would be to an electronic ignition? I read a thread about the Perntorix system, is this the only option?
Thanks,
Jake
Oh My God, find and 1970's auto repair manual they have a good discription of the function of points and condenser, and the convertion to electronic ignition is common
Points are easy and fun. They provide slightly less consistant electricity to the spark plugs than electronic ignitions, but it isn't a big deal. If you are having a lot of trouble it is more likely that your dizzy is wobbling than it being a problem with good points. The OEM Engine manuals, Chiltons, and even Haynes tell you how to do it.
From the F Engine Manual:
all you need is a set of feeler gauges and a dwell meter(optional but prefered) they really are not that bad or complicated.
good worry/trouble free upgrade is a 79+ cruiser dizzy however.
The nice thing about points and a condenser is that it is very fast to troubleshoot and very easy to replace in the field and does not break down often. Pertronix is a easy upgrade for around $90
Good advice
In a pinch the cover from book matches is pretty darn close for
setting gap on cruiser points. In a pinch.
I went electronic years ago. One of the best upgrades. I threw
away my match book cover. :)
I swapped the Pertronix into my 74 F-250 and it has never run better. No more filing points, or making gap adjustments. Install and forget. It runs much more consistently now. I also threw in the 40K volt coil to give the system a little more kick. It runs great now. This is the 1st upgrade the Unimog guys make when their trucks make it to the States. The conversion is also really common on VW's. Good luck.
I went with a D.U.I. HEI cause I was sick of screwing with my points. They're not hard to set and cheap to replace tho. - 2f with header and K&N noticed big diff w/ HEI - The biggest difference I noticed was with water crossings. Much less tendency to get wet and stall out than stock set up.
dang, I thought it was a rolling paper...........no wonder mine ran like crap :D
(yes I have heard that also)
John
another question on this - in the tech section Jim Chenoworth wrote this:
'78: redesigned w/ Med. size screwdown, waterproof cap, electronic ignition. Vacuum advance & retard.
'79-80: dual diaphragm advance. One big advance stage for normal operation, small second stage for extra advance at hi-altitude
81-87distributor body redesigned to use large cap. Same dual diapragm advance introduced in '79.
Does this mean that post '78 distributors are electronic? sorry for the ignorance.
Did the pertronix upgrade, I will never use points again. It's just GREAT
How hard is it to install the Petronix?
Remove cap/rotor/dust plate, unscrew points, 1 screw for the pertronix plate, something to slide on the dizzy shaft (sorry I don't know how to call it)1 screw for the dizzy ground, 2 wires on the coil and it's done.
it's a 30 min. job. good and cheap! :D
79+ US spec= fully electonic, no points.
John
Hopefully you didn't use the matchbook in place of the paper. cough.
The matchbook adjusment works fine. I also second the pertronix comment. I have that and the flamethrower coil on my E1969, runs better, but not the power increase I expected. Only switched because my distributor was getting a little wobbly. I had to trim part of the collar off the magnetice sleeve to fully seat the rotor
I want to throw my 2 cents in here also, I just put it in about 3 weeks ago. Petronix, biggest bang for my buck I ever spent on my cruiser. I was absolutely amazed that a $100 part that small could make that big of difference. Easy and about 10 minutes to install
I wish I would have done it from day one.
Matt
So, you guys that put in Petronix and HEI, what problem is it that you are solving? What is the BANG that you get? I don't think I have a problem to solve, but you guys who swear by it: what is it you are seeing?
In my case ignorance was bliss, I just didn't know how bad it was until I put it in. Not a huge problems, but a lot of little things for me. Starting: it always started, but maybe took 3 to 5 seconds. Now, I'm not kidding when I say I thought I installed fuel injection, turn the key, instantly starts. I sometimes I had to run down the highway with the choke pulled out a little, now, none. Sometimes when I came to a stop after running 60+mph, the engine would die, hasn't happened since the install. Sounds quite a bit quieter now.
These are things I experienced. I know some will say that I should / need to adjust the points better. I played with and adjusted the points, and I thought I had them as good as they were going to get. Personally, I would never go back to points after what I have experienced. :)
Matt
