points?
lunap said:
another question on this - in the tech section Jim Chenoweth wrote this:
'78: redesigned w/ Med. size screwdown, waterproof cap, electronic ignition. vacuum advance & retard.
'79-80: dual diaphragm advance. One big advance stage for normal operation, small second stage for extra advance at hi-altitude
81-87distributor body redesigned to use large cap. Same dual diapragm advance introduced in '79.
Does this mean that post '78 distributors are electronic? sorry for the ignorance.
Electronic ignition was introduced in USA cruisers in 9/77.
All 1978-newer USA cruisers are fully electronic.
You can quickly identify an electronic cruiser distributor by the cap that is retained by 3 screws.
All earlier points distributors have a cap retained by clips.
Owyhee Jackass said:
If it's that easy to install. Could you keep your points in the glove box for "field repairs" if needed?
yes, this is what i did. I put the whole points, condencer(sp), &dust plate in the tool box under ther drivers seat. if need be i could put them back in under 10 mins.
When 1st recieved(1977 FJ40), trying to trouble shoot rough running and smoking problems, I replaced the rotor, points, condenser,cap and wires. It was not that easy due to the fact that the distributor ended up being a Delco Remy from a late 50's Chebby as determined by matching w/old parts by parts store (This may contribute a bit to the similarity questions raised between the Chebby and f-2F).
Tuning up didn't help (currently rebuilding Eng). During rebuild found distributor gear was excessively worn so my boy and I went on an adventure to the bone yard and found and bought a the Dist.,Ignitor and side panel from 1987 FJ60 for $100 (I assume the 87 will work? and was this a good deal?)
Which, if any, is better Later model FJ60 Dist or Petronix upgrade (little late to ask) ? What is HEI and DUI and what is difference?
I don't mean to re-direct/steal this thread......much.
Thanks,
John
John- that is a deal, I paid $125 for the exact same thing.
'87 is the last year that will work.
Even if you did not already have the parts in your hand, i would still much prefer the '81-'87 setup.
The distributor is waterproof, ball bearing (vs the bushing that wears out in older dist), vacuum advance, fully electronic, and toyota. It is everything an ignition system should be.
DUI stands for Davis Unified Ignition. They are a company that basically reworks HEI distributors to drop in all kinds of motors, Toyota, Jeep, International, etc.. They are 3 times the cost of a late toyota setup, and well, not Toyota.
Your carb needs to be ported for vacuum advance to take advantage of the distributor. I am not sure if a '77 carb is vac advance or not. There are several threads on porting for vac advance, do a search.
Bailey,
This vehicle was used on a farm in Merced Calif. and came with some mods. Headers,Saginaw PS, Holley carb (not sure which one or if matters- How can I determine and if it is good?). I also asked Vintage offroad to load the cruiser up with any parts they had and received a few carbs- motorcraft and a couple others).
Thanks for the prompt and detailed feedback.
John
Oh..........No! did you say Vintage Off Road? :eek: :censor:
JJB77FJ40 said:
Bailey,
John
I don't understand the aversion to a points type distributor.
I suppose that if one i s 25+ years old, it could be a PITA.
For what its worth, I looked at a pertronix and decided to pass. There is nothing wrong with a well maintained points setup. You can EASILY keep a spare set of points, a spare condensor, a piece of sand paper, a match book and a spare rotor in teh ash tray of an FJ40. And those parts run all of $15.
Now, if your igniter dies in your igniton coil, then you may want to upgrade to somethign like an HEI.
IF your distributor dies, (chewed up gear is about the only thing I canthink of actually killing a distributor, the bushing is easily replaced) then you might want to cosider putting in a newer one. But all things being equal, I think your money is better spent on Power steering or a rear locker.
My thinking, and this is just opinion from what I've observed, is that as an older distributor wears it starts to wobble. This causes gaps to vary as it spins, and consequently the amount of spark getting to the cylinders varies. I have evidence, actually, with my own dizzies, of which I've played with a few. I have an induction timing light, and when I've used it on an old distributor, I've noticed that the light does not flash steadily, and there is sometimes a miss intermittantly in a cylinder. (This is with new rotor, cap, plugs, and gap and dwell set appropriately). At the same time, there is spark at the plug each time. The fix each time was to replace the usually very old dizzy (only), and the issue went away.
I think electronic systems like petronix compensate better for the variability in points in a wobbling dizzy. But a new points dizzy will perform the same. When people have extolled the virtues of their HEI and Petronix they have all reported fixes to problems that I don't have with my new points dizzies.
Perhaps my thinking is wrong here, but I've done it successfully a couple of times.
Talk to me. What is the story? All I see is negative feedback. I bought it before I knew about this forum. I did have a run in with him but I think I may have gotten the better of the deal. I was buying one of 9 FJ 40s all priced at $2900 and because I was the 1st (supposedly) He promised me the best one. At the time he didn't know what he had but as it unfolded it ended up being that he had a 77 with power stearing and the rest were from 69 - 76. When I advised I wanted the 77 he said I couldnt have that one unless I paid $4200 (power stearing, front discs etc) and forwarded several emails stating our agreement but I had no leverage. So I agreed to the next best. However because he was arranging the shipments from Minn.(I believe) his partner messed up and sent me the 77. A week or two later he called saying I could keep it if I paid another $1000. However, this time I had possession and argued it would cost him more money to ship both LC's to opposite corners of the U.S than the $1000. I guess mine went to someone in Texas. My cruiser is rot free with some rust at some seams (I didn't expect the engine to start but it did and that was a plus).
So what are the other stories?????????? I would love to hear them.
John
I broke a new set of points and got pissed off and went HEI. I got the diz from a friend, a mechanic, and he checked it out. The whole thing cost me about $80.
I was really pleased with the performance until someone pointed out that I have it hooked up to full manifold vacuum. Now I feel like a Dickhead for liking what I had/have. The cruiser is up on blocks getting 4WDB, new master, lift, etc. So I **** wait until I replace the throttle body with a ported vacuum and I can REALLY see what a difference the HEI makes.
JMO
Ed
John
BTW, your's is one of the better stories. Who cares, you have a Cruiser which is the Ante in a game where you can go broke and enjoy the trip!
Your seller is a dickhead, but that doesn't matter. You ended up on top on this deal!
GL
Ed
sounds like you did great........very cool :)
John
