Is there PM list for SuperCharger? When do I need to change the belt, and any other things? I have new belt ready to install.
Thanks,
Thanks,
If the belt is not cracking or look worn, no need to replace. Same as with fan belts. Take a good look at a flashlight to both sides. If it's looking worn, go ahead and replace since you already have it.
Leave everything else alone with the excep[tion of any cracking or brittle hoses.
Scott, is three a mileage on the supercharger you are recommending for the oil inspection?
Has anyone else done this to see if the oil level dropped? I know Cdan has about 60K miles on his.
I cked mine on install. I service a couple more traditionally mounted SC's in other applications at my shop. I'd say 20-25k is max, and expect to add a bit more oil than you think reasonable. IME2, if you hear any additional gear whine/noises from normal, or it just 'sounds' louder, probably a good time to remove and do a fluid ck. There really isn't a need to do an oil change (but not a bad idea given you have to do a R&R on the unit for this service) and beware that oil is *expensive*.Well I've not done anything about it. I was acting according to council from my TRD bud.
Do you know that the oil capacity is?
Yes, it's got to come off and hit the bench. If I do go to that much trouble I think I'll just keep going and put a head gasket in it.![]()
As my snout gasket has a slight wisp since I got it, I'll post up the R&R for this before I go to Steamboat in a few weeks.
ST
Scott, could you take pictures of the process?
Thanks
