Pinion Issues?
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
Well as most of you know I've got drive train issues from the PO. And I'm trying to straighten them out. I've got a vibration only when the drivetrain is NOT under load. Replaces output shaft bearings on transfercase and have a new driveshaft on the way. Someone made the suggestion that it could be my pinion and to check for side to side play.
Well I checked it tonight and I do have sisde to side at the flange. About a 1/16 of an inch. Is this bad. I'm assuming it is so I unstaked the nut which was secured correctly and tightened the bolt a little till there was no play and staked it. About an 1/8th of a turn. Now no play and I still can turn the pinion with the same force. My concern is I have now gotten the pinion out of allignment with the ring gear and will cause more problems. What do you think?
No it won't change the tooth contact pattern or backlash. You need to ask why there would be play with the nut properly staked? The two possibilities are: The nut was never properly torqued or the bearings have worn/failed. Chances are it is the later, so did you check the bearings or at least check the magnetic drian plug for metal chunks? If the bearings are shot, just tightening the nut won't work for long. The good news is used differentials are cheap.
Nut was staked. I'm thinking bearings. I just changed diff fluid a month ago and didn't notice any metal.
And I thought about an extra third. I bought a used third from nolen last week. :D
I have a little play in my pinion too. I have a back-up diff I want to get in there. I have never done a pinion/ring gear set-up, do you have to remove the whole enchalada to get to the pinion bearing?
Probably a stupid question...
Rezarf <><
just got done
setting up one of my diffs for 4.88's
it was alot easier than i thought it was going to be.
the main thing to first do was to measure the pinion depth.
after that, piece of cake................mmmmmmmmmmmmmmm....cake ;)
i think it also depends on what year diff your working on as far as how easy it could be.
i only had shims to deal with, no crush sleeve. :D
3rd possibility
The 3rd option would be if you spun your shim...
