Pinging at 113 degrees……..
Prescott Valley, AZ
So had to do some highway driving today in the Phoenix heat🙄. It was mostly all highway driving at 50mph on my Speedo which is probably more like 56 due to my rubber overdrive 33” tires. Temp gauge read slightly higher than normal at just above 1/3 hash mark but below what would be half way in the gauge. Is this normal in extreme heat for what is typically great running 2F? Fairly original as well, rebuilt original Aisan carb by JimC. I purposefully run premium fuel in it in the high heat, all other times 87. Opinions appreciated. It normally runs at 1/3 in temp gauge. I guess at 113 anything can happen. Thanks guys….
I should also mention probably drove close to 100 miles rountrip. Thanks
What could cause this, or is this to be expected in crazy Phoenix heat? Incidentally newer OEM 4 core radiator and thermostat, truck has not history of running hot, even with old leaky 3 core prior to my basically pretty fresh cooling system. Thanks
The hottest spot in the engine water jacket (#6 head passage) will run 100 to 125 degrees above ambient when the thermostat is wide open. So on a 100 degree day, you may see temperatures 200 to 225.
Thanks for this. So some pinging is to be expected? Primarily level roads, no climbs into the mountains today! My current timing is approx 10 degrees before TDC at idle 650RPM.
@tls3601 Nothing in the body of your post talked about pinging, but based on your thread title I'm assuming you heard some pining/pre-ignition going on? Or are you just assuming it is pining because the temp gauge is showing higher than normal? Pinging or pre-ignition would most likely be a timing related issue.
id be more concerned with the lower oil pressure at those speeds/rpms.
the temp gauge is well within the normal running range.
Pinging at 113…..title of my thread. Running at 10 degrees BTDC. Does not seem to be excessive. I know 7 degrees is stock. I didn’t notice it before when I was living at a mile high, 5350 ft. Valley is 12-1400ft.
Could I be running too much advance at the lower elevation I now live at, or is it possible my vac advance is not working properly? Thanks.
I just had a somewhat similar conversation with @powthief19 a few days ago. Don’t discount the possibility that the fuel in your tank, which was blended based on weather forecasts several weeks ahead of delivery, may have just netted you a less than optimal tank.
Unless symptoms are severe, I usually recommend running down the fuel and refilling before making any changes.
I have to agree with Mark. Run the the tank down and fuel the tank. Next wound move the timing back to stock.
Oil pressure doesn't seem that bad to me unless your running 50 weight. Gener ran heavier weight oil when I actually ran a 40 in Phoenix during the summer which has been a very long time ago. What weight are you running?
Lastly I know you have a modern vehicle with A/C why are you driving an FJ40 in 113 degrees? Even with the vent windows in the top it's still hot.
Good question John! Ha ha a friend helped me do some new axle shims on rear axle with new hardware as well. I am running Mobil 1 Synthetic 15W-50. Needed to get drivetrain angle right. PO did lift but never addressed this most important aspect🙄. Is it possible my vac advance is not working properly? Seems like lots of fluids like to seep out in this insane heat!
Too hot to camp, lots of our Forests are closed in the elevations up North so not much else to do but knock off some things off the “to do list” on the ‘78. Friggin hot though, had cooler with ice cold drinks in the passenger seat with me for the drive👍
Funny thing is put fresh fuel in just yesterday as it was down to 1/4 tank. Maybe 10 degrees is too much advance for this lower elevation. Top her off with some fresh fuel, and see how she runs next time.
Elevation does make a surprising amount of difference. I can't speak for the 2F, just aviation experience... but my plane needs 100 octane at sea level, and it could run on 91 by ~4000' due to natural compression loss with decreasing air density.
My hunch says bump the timing back to stock and it'll be right as rain...just a hunch though.
Pinging is usually caused by timing being too advanced for the fuel. If the timing is retarded a bit it should go away. My ‘77 distributor had a nob that could used to find tune for octane.
FYI - I'd suspect the numeric value of your temp gauge shown is about 207 degrees (+/-). A few weeks ago my rig's temp gauge got about that high sitting in traffic on a hot day and the Sniper display showed around 207. Once I got going constantly again, it dropped back to around 190 (+/-) and just below the 1st tick-mark....Noted, it wasn't in 113 degree heat, maybe mind 90's.
I'm with Brian. I've never seen low oil pressure like that at that temp or speed on my rig.
Pinging can also be caused by glowing carbon on valves or plugs. Maybe one of those telephone-bore-scopes/camera can reveal the condition of your valves? On carbs without idle cut solenoids (or at least wired to the On/Start circuits), dieseling at shut-down indicates unintended ignition.
Your description of temp gauge reading is very consistent with mine, both for 100*F temps, and for cooler temps. Normal to run just to the hot side of the 1/3 hash mark when >/= 100. (My 2F is all configured as original, including emissions.) I'm running a new 4-core OEM radiator (TRad), new thermostat, and the cooling system is well maintained. One more data point for you, the 1/3 hash mark on the temp gauge seems to be the "magic mark" where the fan clutch starts to lock up much more frequently, particularly when pulling away from a stoplight or similar situations. Typically stops roaring by the time I'm up to 20mph or so.
As far as the oil pressure goes, my '76 was running low pressure on the gauge similar to yours. My oil sending unit was original. Toyota still makes these units (if your sender is like my '76) I replaced the sender with a Toyota factory unit, and the pressure went way back up. See photo.
My rig, with factory 2F /Aisin will talk a little to me when it is hot outside, warmed up and I get into the secondary of the carb, even with high test in the tank. Maybe a little SeaFoam treatment would help for the glowing carbon in the cylinders? There are also distributors that: advance with rpm, and retard with rpm. Is your advance plate in the distributor working correctly? There are small ball bearings on the advance plate that may need attention. See photo.
