Perfect Tire?
N ONT
I have run 6 different tires on the 80 over the last few years and each has it's own pro's and cons.
Q7815LT Buckshots - Great in the bush, Perfect size, Super loud on the road, never trusted the Bias at high speed
35x12.5 SSM16- surprisingly quite for an aggressive tire, went out of balance terribly, size was a "little" small, Crazy expensive.
33x12.5 old MTR's- good all around tire, just too small for my 80, terrible in the cold (had my 80 go sideways from slight engine braking on bare pavement!!)
285/75r16 Cooper stt? (the "old" ones) good tire, didn't clear that well, too small
285/75r16 dunlop rover rvxt - road tire, nuff said.
325/80r16 Dick Cepek FC-II's- great tire so far, not sure about "hard" wheelin' as I have yet to try out, rub a little with 2-3" lift
I also had a set of 33 tsl radials on my 95 minitruck, they were the best tires I have ever had for offroad performance and on road manners.
MY QUESTION, is the 36x12.5 tsl radial the "perfect" tire for our trucks tire that can be driven daily with minimal suspension upgrades and best off road performance?
When asking for advice about buying rubber it would be helpful to provide where and how you are going to use the rubbers. Simply saying one rubber is too big or small isn't all that useful as everyone's size preference is different.
Also perfection is the greatest enemy of good, find what characteristics are most import for you and go from there.
"MY QUESTION, is the 36x12.5 tsl radial the "perfect" tire for our trucks tire that can be driven daily with minimal suspension upgrades and best off road performance?"
Was that not enough information for you? Best off road performance (all around) AND on road handling with minimal lift. What else do you want to know?
Also "perfect" was in "" for a reason.
I have that size of TSL radials on my 55 (15 inch rims). They are a true 36" tire which is unusual. I can't see them fitting on an 80 without a pretty big lift. As typical of super swampers, they are cheaply made, hard to balance, have weak sidewalls and probably won't last that long. They are also pretty loud on the road. BUT, they are great for the price and do wheel well. It really depends on your highway vs wheeling ratio. If you are more wheeling than highway, they are probably ok if they can hold up. If you are more highway, run KM2s or Toyos or MTRs, or any of the tougher, better made, more expensive mud/AT tires that wheel well but are quieter and handle better on the road.
Where did you find the 325/80r16 FC-2's? Was told about 8 months ago they are no longer made.
Smokin deal on a used set, 600cdn for four mounted on procomp's, 2/32" wear from new. Trouble is, no spare or replacement is available.
not much lift needed at all, 35's fit stock.
As typical of super swampers, they are cheaply made, hard to balance, have weak sidewalls and probably won't last that long. They are also pretty loud on the road. BUT, they are great for the price and do wheel well. .
I remember feeling how thick the sidewall were on my tsl's, and must say they were the thickest sidewall I have ever felt, not sure where this is comming from? They were also very quiet given the tread?
So is this thread really about the best used discontinued tires for an 80?....This is a pointless conversation, so I will join in. I have only ever had one set of new tires since I have owned my 80. 285 75r16 Yokohama Geolander AT's, and they are by far the best tire for the 80 series as far as I know.:rolleyes:
I never mentioned used tires in the original thread, and I was inquiring incase I need to replace all 4 because of a sidewall issue. If you think it's pointless, get lost, and keep your condisention to yourself!
The best tire varies greatly on a large range of factors. Location, terrain, conditions, type of primary use ect ect.
I may feel that Micheline LTX tires in 275/70r16 are the best all round tires for a 80 series. But my neighbour may think that his 40" bias boggers are the greatest tires on his 80 series.
There is no perfect tires.
Lighten up Alice, just having a little fun. These conversations are pointless, there will never be consensus because everyone has their own criteria based on terrain and intended use of the truck. I will just let this thread die out and prove my point that way.;)
Why let it die? OP's style and touchiness are pretty entertaining so far.
Thanks guys, its db's like you guys hyjacking threads with attitude thats gives forums a bad rep. I just wanted to get some peoples educated opinions from real wheeling experience before spending a couple grand. Im sorry your not capable of providing that.
Easy answer is no, there is no perfect tire. Tires depend on so much. Tires I use here in the desert and rocks are going to probably be a lot different than what you'd want for mud and snow. I personally think 315/75R16 tire is perfect size for a stock to 3" lifted 80. ;)
That said, I've run:
265/75/16, 285/75/16, 315/75/16 BFG KO's
285/75/16 and 315 MTR (Non kevlar)
285 and 315 BFG KM2's
315 Toyo MT
For both offroad and onroad performance in my area, I thought the old MTR was the best. I tried buying the new MTR but they were on back order. My new Toyo MT's seem too heavy, not that great onroad but good offroad. Just got them and don't really have much time with them yet.
Edit. Only reason I didn't like the KM2's were because they were way undersized/smaller than the same sized KO... Otherwise great tires .
Your neighbor is clearly smarter than you. :flipoff2:
My perfect tire is the GY Duratracs 285/75/16. Fits my needs fantastic, looks good, and gets the chicks! Goes thru 3 ft of snow when needed, lets me drive on my lawn, is relatively quiet, yet makes my truck look BA when it's standing still.
Better than the BFG's of yore as well as the Star Mud-Terrains that I once had.
Not much use in my world for SS or bias ply. I'm not that hard core.
I think I'll copy this post to the other 138 threads on this subject.....
Good Luck with your TSL's.
I would never run a Cooper on anything I own. All I've seen is they come apart.
Now that I'm older, wiser and have a little more money than I used to, I go with better quality for my needs. Otherwise, I'd just shop CL for a set of used rims and tires like I used to do.
It was an example of no perfect tire. It's only perfect in the eye of the beholder.
Personal opinion I liked my 35's Duratracs, they have great grip in the snow, sand and logging roads. They suck in the mud but that's not my thing.
I have also had 33" truxus Mt's (great tire), BFG KO (s*** tire), BFG muds (again not impressed) and 37" Pitt bull Rockers (great off road good on road wore faster).
This thread is just going to get filled up with peoples personal opinions of what is best and in that regard no more useful than every other "what tire should I get" thread.
Cooper st - the old st style - still avaialble and are a commercial rated tire. good life, reasonable off road. I've had two sets. They are still available but you got to motivate the tire shop to get them
Why can't we all just get along. Finding the perfect tire is like trying to find the perfect chick. It just doesn't exist.
