Does anybody have a pattern for the side glass for a 75 top. I have contacted every glass shop close to me and nobody has the pattern.
Would be great if you could trace it on paper. I would think it would take a commercial type of printer to print it out.
repliedStumpalama sent you a pm.
When I asked about cutting the side glass I was told it would be tempered. Did not ask if it was DOT approved. I did not measure what thickness my door glass was but I assumed 1/4" glass would work.
@Stumpalama I can measure my openings if that would help.
So, one set is longer and not as "tall" as the other set... @Rusty 72, does your window rubber use a chrome "key" to retain the seal or is it just straight rubber? From my searches, it seems that the later, bigger, glass fits your truck. I think the openings are the same, but it's the seal that makes the difference.
I picked the sides up last year and did not come with glass or weatherstriping. They are for amby doors and have one piece side glass. If I am correct they are from a 75 or 76.
Will get the measurements when I get home in the morning.
You aren't going to GSMTR, by chance are you?
FYI - Cutting the side glass for the doors. When I refurbished my doors and had the glass out, I took them to my local glass shop to cut me a couple of units. They said they couldn't cut that type of glass because they didn't have the thickness nor did they have it in a DOT approved glass. I called every glass shop I could find, and this was their standard answer.
