I still have all the pictures from the fan meet radiator incident if you want them. I think @GA Architect may have a few as well. Hope everything is going well.
-Noodle
-Noodle
It would be pretty dull, right up to the point where it meets its likely demise following an encounter with a deer or cow at warp speed on a dirt road. Updates would consist of the following:I get the time constraints man. I think as they get older it may get a little easier.
Think the Tundy Badger needs a build thread on Mud.
Very much so! Although the other 40 gets the tree dragging duties around here, the midwest woods are hard on a rig!Glad to see Patches is still with us. I put the 40 to work for the first time in probably 9 months yesterday to drag a pine tree that blew down out of the yard and to the curb.
New pump has been for a while, pretty happy with it. I haven't played with the speed limit on it, being able to run it up to 2500 RPM has been a total gamechanger for driveability, and I'm not sure I need much more. It feels like torque is already falling off at that speed, and it just sounds angrier. I've put about 2 tanks through it deiving to work and back, which is ~10 miles of gravel at 35 mph, 15 miles on the highway at 70 mph, and another 15 miles of 2 lane at 55-60. I've been using the newfound power more than I need to and have averaged 25 mpg since the pump swap, which seems pretty good.
I did try a larger turbo, (a 2252 clone) and found it too big. Very laggy at lower speeds. I've got a 2052 I may try, on paper it seems alright.. but after driving it with a bigger laggy turbo I really appreciate the response of the little guy it came with, and will focus elsewhere for now.
I've been collecting materials to do some insulating and interior decorating. I've got Raptor liner + tint, Kilmat, Siles Hybrid mat (foam sandwiched between butyl rubber and mass loaded vinyl), foil backed foam, fiberglass cloth sheets, etc.
As I intent to add A/C in the near future (leaning towards the Nostalgic Air unit), I've made some DIY insulating coating, using elastomeric flat roof coating and microballoons. I mixed some 50/50 (took some mixing!) It is too thick to spray, but can be brushed on pretty easily. Initial testing seems positive; I painted some (plain and mixed with the balloons) on a piece of painted 16ga sheetmetal and poked and pried on it as well as hitting the backside with a torch to see if the balloons made a difference. It's definately lighter, a little more "squishy" and easier to scrap or tear with a screwdriver with the balloons in it. With a torch to the backside of the steel, the difference in heat getting through to the front of the coating was very noticeable. The side of the steel with the balloons in the coating I could hold my hand on easily vs. the other side being burning hot. I kept going until the unaltered coating began to bubble up and lose adherance.
I'm very interested in how durable this stuff might be under raptor liner on interior wheel wells, floors, etc. Too thick and I think point loads would crack the raptor over it.
I think I'll take an old hood or something and do some experimenting. I'll put some epoxy down, do an area with the coating at ~1/16" thick, another at ~1/8", and try some strips of kilmat (roughly the width of the floor ribbing) and then coat everything in raptor liner. This will allow some experimenting to see if either the coating or the kilmat might hold up under raptor liner. I intend to drag the hood down the gravel road, beat on it, pepper it with some #7.5's, etc. If all goes well, I'll have a coating I can put under the raptor to help insulate the rig and be able to keep sound down. If it doesn't hold up as well, I'll probably just confne the coating to the underside of the roof cap (to be covered in headliner anyway.)
I've also got an MR2 intercooler I'm going to get plumbed in, and need to rework the intake side to use a real aircleaner vs. this cone filter I've been running.. that's after I've removed the heater box and made a battery tray to sit close to the firewall on the passenger side to free up some room for the AC compressor and filter housing.
At the least, I'd like to have the A/C done and interior surfaces coated/lined/sound insulated before August so we can take this thing to Solid Axle Summit. Best case, I'll have some time to get the doors and hardtop off and blown apart (some minor rust repair work is needed on doors and some hardtop pieces) and get the whole thing painted... we'll see!
I also finally installed the grille guard that @NookShneer nabbed for me in Seattle and delivered to SAS a few years ago, along with some Kioto fogs from CruiserCult. View attachment 3872145
I think this one came from a 4 door with the turbo 4 and towing package. I don't think they're all 850w. I was "blown away" when I powered this thing up, it's absolutely amazing the air it moves. There are also 850w BMW and Camaro fans (and $pal aftermarket) but I'm not sure the dimensions on those. The JL ones are easy to find anywhere. It was about $100 at the local salvage yard and they had many of them on the shelf from low mile very new JL's.I might have to give that fan a try. I'm in need of some more cooling capacity.
