Part Time Regret?
Video of burn outs or it never happened.
Do neutral drops count?
It would be fun to be able to lock the rear in part time and do donuts on the front axis in an 80 like I used to be able to do in my 91 pickup with the ARB.
When my Jeep GC t-case died, I wet to a part time unit and loved it. I was surprised that it made it quieter in the cab and it steered easier.
If I decide I have extra cash burning a hole in my pocket or my VC dies, I will change my LC to PT.
I like lockouts and lockers and doing 2WD donuts. Put it against a curb and see if I could get the tires to burn......
Can you roast the tires in 4th gear or only 3rd
I can get sbout 80 mph of wheel speed on my TURBO 80 in 2nd then it hooks up. I want try it low range but I was told the transfer case would not hold up with all the power going to the rear.
Barring the possible savings on fuel, I have yet to read a genuine and credible reason to change to PT.
better steering feel, fix driveline vibes, extend life of cro-mo axles, easier to get home from a break, etc.
Personally I went from 12.5ish hwy mpg to a steady 15. That said, the biggest selling points for me were what @4rings5cyls listed, especially being able to disable the front axle internals and get out of a situation more easily.
I have manual hubs on the front and still full time AWD. While not a daily driver I like the AWD.
I can lock the tcase and unlock the hubs when I want to. Just don't unlock the tcase before locking the hubs.
I did the part time and the low range gears at the same time. I am really happy with the way my truck drives now. I have a Slee 4" lift with 35s, it drove nice, but there was always a vibration and slight rumble on deceleration. I assumed it was the u joints on the rear driveline, so I replaced them with OEM and it was slightly better. I decided to pull the front driveline and lock the CDL to see if that was the problem. Once I did that the vibes were gone and it drove so smooth and quiet. At that point the part time was a must for me. I couldn't be happier. I get very OCD when it comes to that kind of thing and the part time kit fixed it for me. It's not cheap, I think I spent something like $1600 for both and did the install myself.
Meaning the 2wd rollers can do 37s? I was not aware of that. That in and of itself would make me do it. I just passed on my old 34s before switching to 37s, but was just planning on driving by some of the vans they park on highway on ramps.
There are only a hand full of testing centers that will test over a 33 inch tire. The first time I had to buy a set of old 265s to put on so I could test it in AWD. But now they can test larger size tire but I believe that it is only RWD. That's the only reason I haven't made the jump to 37s because I don't want to have to change out tires each time. Plus I haven't been able to pass the road side test. See link below.
m.aircarecolorado.com/index.php#page64
To be able to dig the rear into the dirt for leveling the rig when it comes time to crawl into the RTT is just too cool for school. :flipoff2:
No regrets at all. I don't even remember that it was once AWD until I see these threads.
I've considered doing this. However, after the snow and ice we had this year and how amazing the AWD was, so amazing in fact my woman woke up early a few mornings to steal my keys and drive it herself, I just can't.
However I see locking hubs and disconnecting front driveshaft for long trips to be a real benefit.
I can't risk the epic snow and ice traction.
I am hesitant to do it for the same reason...winter traction. Part time 4wd just doesn't work as well as AWD unless you only drive in a straight line and the amount of traction available is consistent.
The transfer case in my old Cherokee (NP242) had full time 4wd, part time 4wd, and 2wd. If only such an option existed for our trucks.
I absolutely agree that that you may save some gas because you are not driving an additional set of gears.
Rolling burnouts, yep I more than get that, but it was many years back in my V12 manual Jaguar two door Coupe, more smiles per mile than ANY other car I have owned! :D
Levelling the RTT....oh alright :D
Better steering feel? The variable power steering on these older cars tends to mask that so unsure about that? :confused:
Re the steering radius, I tried mine with RWD only and could not believe how less stable the car was through fast......ish bends. I am not talking about trying to get the tail out, I am talking fast progressive driving on the coast roads. With the rear wheels pushing the car forwards and the front tyres trying to turn the mass, it was a typical under steer experience, the AWD allowing the front wheels to help 'pull' the car around the bend, a much more balanced and neutral drive. I know this is always a hot potato, and once you have dropped the coin owners need to defend that decision, and given the mileage the gasoline version gives, that alone is good reason on a DD but, at the end of the day you cannot overturn the laws of physics.
regards
Dave
Why would you buy a AWD if you don't want one, I have a bad VC pulled the front drive line, and ran forever in 2wd once I put a new VC in it and ran it AWD like it was designed to be, I love it, it corners better and drives better no change in MPG . I installed CDL and it has saved me in the ice and snow, and again why would you buy a ADW when you want a part time SMH
i'm with ian. i have had the hubs on for years. never got around to doing the pt tcase spool in my 95 and now that i've been wheeling the unlocked 96 for a long year, i don't know that i want to get rid of the all wheel drive. the viscous coupler just flat out works.
There were part time 80s in other markets so it's not reinventing the wheel or making the truck something It wasn't built for.
