Yes the cardboard trick is great as long as you keep it rotated properly. The owners manual does not explain the system very well. It says to use the lever at "H" and the differential lock button left out for normal driving on all types of roads to wet, icy or snow covered roads. This position gives greater economy, quietest ride, least wear and better vehicle control. Use the "H" speed position with the center differential lock button pushed in for greater traction when you experience a loss of power. such as wheel slipping in the center differential unlock mode. Sounds like the center differential lock engages the front wheel drive. If that is what it does then the system is free wheeling most of the time. I just thought part time hubs would stop the wear and tear on the front wheel drive components and provide a little better mileage.
