Painting Front Grill
Indiana
I know I have found detail about painting the chromed area on a front grill/headlights but can't seem to find it. Can anyone tell me a bit about what needs to be done for prep and/or direct me to the thread? Appreciate it.
Mostly need a Phillips driver, masking tape, and a skotch pad. I did not use any chemicals to strip chrome. Seems i recall a thread that had success with some form of stripper but a few that had failures mucking up the plastic.
Scuff it well, focus on the creases. Use a good paint and follow the recomendations (temp may be an issue at this time of year in IN). I got about 5 years out of john deere blitz black before rocks and bugs started to reveal some chrome speckles.
I think the trim around the turns is not removable so the tape comes into play there
Quick mud search of 'painting grill' shows---
A) soaking in bleach for 24 hours removes chrome from plastic
B) plastic plating facility can dechrome and recoat as well
C)
I'd recommend a good degreasing, a good scuffing, another good degreasing, and then using Plastidip in lieu of spray paint. I've used it a ton on various vehicles and it's held up great over the years.
I wouldn't even bother scuffing. Just clean and degrease it and spray it with plastidip. I did all the sanding etc prep several times in the past followed by paint. Then on my Tacoma I decided not to bother with all the extensive prep and just tried the plastidip to see how it worked. The finish was great and the plastidip proved to be better longterm because it has somewhat of a flexible finish so it doesn't chip (rock chips etc) in the same way paint always did for me in the past.
More importantly, you're not permanently damaging your original grill by sanding etc. Decide you want the chrome back in a few years, peel off the plastidip and it looks original again. I've simply cleaned and sprayed my Tacoma grill and now my 80 grill with excellent results.
Here's the Tacoma grill after 4 years (just before selling the truck)
Here's my 80 the night I sprayed it. Still looks the same 2 years later.
I am planning on doing the center section of my hood when it warms up again. I found this resource for plastidip products. TONS of how-to videos and they sell products as well. www.dipyourcar.com I have NO affiliation.
For large areas like a hood, I don't suggest using the spray cans you can get at the store. The finish on large areas from the spray cans is not great. Using a sprayer like Dipyourcar recommends when spraying a whole car would be better. BTDT.
Thanks for the insight all. I think I will prep the chrome with a sanding, degrease and then the plastidip. I just don't like chrome that much.
Is plastidip a long term solution? Thinking about painting my fender flares and grill but I don't want to do it again in a few years if there is a better solution? I am trying to find some threads on painting the flexible plastic parts. My flares are peeling and in rough shape. Looks like the previous owner dripped some gas or something on the rear flare too.
No need to sand with plastidip and it won't improve how it adheres. Clean it well, degrease it, wipe it down with 70-90% alcohol and spray. First coat real light, second a little thicker, third as thick as you can without it running, set in sun to dry and done.
I think PlastiDip is as long term of a solution as anything less than a full on prep/paint job. And, it's far easier/faster/cheaper. Law of Diminishing Returns definitely applies here... Even with a full prep/paint job it will still chip over the years from rocks/gravel/bugs.
PlastiDip is a no brainer for this application. I would only think that scuffing is necessary if you have some existing flaking paint/chrome on your grille. I did, so I scuffed mine to get rid of anything loose.
Before/after of mine...
I used plastidip for the window trim on the bottom of the doors for my prelude (same construction as the 80 door windows, metal bottom piece) - I stripped all the old flaking crap with a razor knife, and scotchbrite (red) the metal to give some tooth.
That was what was recommended if you wanted a permanent bond, not pulling it & doing something different in a couple yrs.
Hmmm... I wonder how plastidip colors (not black) hold up over time? Thinking about dipping my lexus cladding in a graphite or gunmetal color to spruce it up until I rip it off on a tree. PO's touch up paint looks horrible within 20 feet.
I've not found a plasti-dip that's similar, but the Duplicolor HWP102 is a pretty damn close match to the LX wheel graphite. I painted my center caps with this.
That is exactly what I am wondering. I did a little Youtubing and the stuff stands up to keys and is flexible as hell. So unless it catches an edge which would rip it off, I don't think it is going to be easy to pierce with a limb. Only one way to find out though.
Blatent thread hijack - what hood vents are those?
You have a build thread?
Continuing the hijack... :flipoff2:
I'm not sure on the specifics of the vents as they were (poorly) installed by the PO. They appear to just be some generic louvers riveted on...
Build thread is linked in my signature.
/hijack
I'm not sure I would use plastidip on areas that are likely to be impacted by rocks like the grill or fender flares. I had it on my grill and after it started to peel off I decided to try and remove it and replace it with some kind of bedliner. Let me just say it was a bitch to remove. Once I finally got it all off I scuffed the chrome as best I could and sprayed on some Rustoleum bedliner. It started chipping/flaking off in less than 6 months. In hindsight, I probably should have tried some kind of adhesion promoting primer like @davework mentioned above.
If I had it to do over again, I'd have the chrome removed by a plating shop, prime it properly, then spray with Monstaliner.
Anybody tried Monstaliner or LineX on their grill or fender flares? I'd love to hear about their experience...
