Here is the OEM part list I got for the swap. There are comments under some parts, you should read if you are interested:
COOLER ASSY, OIL, STEERING
44420-60220
HOSE, PRESSURE FEED, STEERING
44411-60430
HOSE, OIL RESERVOIR TO PUMP, NO.1, STEERING
44348-60170
TUBE, RETURN, STEERING
44416-60310
PUMP ASSY, VANE, STEERING
44320-60340
"So 1FZ pumps have three different numbers, this one for 79, and I don't know why there are so many numbers. We will try this, and if it doesn't fit the build, I will change to other numbers"
RESERVOIR ASSY, VANE PUMP OIL
44360-60200
STARTER ASSY
28100-66030 - 12V, 2.2KW.
"80 series part"
"Cold spec, I thought a guy from far north may buy it, so I went cold; Not for Canadians tho"
COMPRESSOR ASSY
88320-60450
"80 series part"
ALTERNATOR ASSY
27060-66090 - 12V, 80A.
"Lucky truck, I got the 80 amps for it. There is another number for 100 amps, but at least we didn't go 70amps"
PUMP ASSY, ENGINE WATER
16100-69415
COUPLING ASSY, FLUID
16210-66040
"This part number is for FZJ100"
FAN
16361-66020
COVER SUB-ASSY, OIL PUMP
11310-66020
"Because why not?"
STRAINER SUB-ASSY, OIL
15104-66011
PULLEY SUB-ASSY, IDLER
16603-66010
PULLEY ASSY, IDLE
88440-26090
SENSOR, CRANK POSITION
90919-05041
SENSOR, KNOCK CONTROL, Set of 2
89615-30050
INSULATOR, ENGINE MOUNTING
1236117011
STABILIZER, ENGINE MOUNTING
1238166010
HOSE, VENTILATION
1226266011
HOSE, VENTILATION
1226166011
VALVE SUB-ASSY, VENTILATION
1220435040
GROMMET
9048018001
GASKET KIT ENGINE
04111-66101
"I am not going to unplug the head, but I want to replace everything in the kit, including valve seals"
INSULATOR, DASH PANEL, OUTER
55223-60112
INSULATOR, HOOD
53341-60100
INLET, WATER
1632166011
THERMOSTAT
9091603117
GASKET, THERMOSTAT
1634666020
HOSE, RADIATOR, NO.2
1657266021
PIPE, RADIATOR, NO.7
1657766011
HOSE, RADIATOR, NO.3
1657366010
HOSE, RADIATOR, NO.1
1657166030
OUTLET, WATER
1633166040
HOSE, WATER BY-PASS, NO.1
1626166030
HOSE, WATER BY-PASS, NO.2
1626466010
