Two cans of 44k in one tank of gas, helps free up spark plugs. I've had to repeat as much as 3 times, to free up plugs. Penetrating oil, like Seafoam in spark tube can be beneficial also. Seafoam then ends up in cylinder and helps free up rings along with valves & piston carbon.
Number one cause of plugs freezing in head, Anti-seize used on threads. Carbon build-up is second and not near as bad.
BK 1 is ods and on DS. BK 2 is even and on PSYeah definitely not throwing parts at it. Stuff that I would consider "normal maintenance" is getting handled, like the plugs. Every... single... one... has given me grief coming out, finally had to get out my 24" ratcheting breaker bar to get them out better/easier. Still working them slowly though. Problem is that it is large enough that I cannot get to the last two cylinders #7 & #8, so gotta figure that out.
Had one coilpack last night that had cracks along the body of the coil so I replaced since I had the two Densos that I purchased. Put new one on Cylinder #1 to see if that resolved that code, and not dice thus far. Replaced the cracked on #6 for good measure. Going to the buddies place after work tonight to do some more troubleshooting. This morning on the way to work she threw a P0300, P0301, P0305, P0307 but no P0171. Think she was throwing codes just because I had been spraying around the intake to see if I possibly missed a vacuum leak last night. CEL started blinking as I left the house but light didnt stay on, and when I tried to read codes nothing was there... Wasn't until a few lights later that it did same thing again and light stayed on that time which is how I got the codes. Funny thing is that in all of this, when I am monitoring through Techstream, cylinder #6 is the ONLY ONE that doesn't have misfires.
We will see what we can come up with. Unfortunately my EZ Out didn't work last night for getting the sheared bolt out. Gonna talk with him to see what can be done, really hoping that I don't have to remove the valve cover to get it out, I know he said he has a good set of lefthand bits so maybe his stuff will be more successful.
I did drive her to work this morning and while she did the normal stumbling/rough idle at the first couple lights, by the time I got to work she was running rather smooth. So who knows. Maybe something like the Crank Position Sensor, Camshaft Position Sensor, Fuel Pump, Fuel Filter or something else is causing issues. The two things that have me really questioning what is going on is the Fuel Trims and the one O2 Sensor that is constantly at 99.15% (Bank1Sensor2)
Just to confirm that I am not going crazy... Drivers side of the engine is Odd Number for cylinders (1, 3, 5, 7) and Passenger side is Even Number (2, 4, 6, 8) correct? Which would make Bank 1 passenger side and Bank 2 side, correct?
