Porn doesn't usually cost you thousands of dollars.
Touché!
so it may be just as easy to climb up on the tail gate? I have the roller floor with a National Luna 50L Fridge/Freezer. It does not rattle and pulls out far enough for the lid to open fully. I ordered the optional mounting plate for it and it makes it very secure for the pounding it takes off road. No worries or hassles that folks that use bonji cords have. 2 latches and it is free to remove from the rig. I highly recommend this combo for Overland setups. I also have the roller drawer underneath with one regular size drawer next to them. I have a RTT, so sleeping inside the rig is not an issue. Rock solid setup, but as you've already seen - pricey.Thanks for the feedback.
For those that have the drawer with the roller floor (not a separate fridge slide), does it rattle at all? It seems like it would with the extra moving parts.
Does the roller floor extend far enough to allow the shorter ARB fridge (37/63qt) lid to open all the way or does it hit the hatch/roof?
I would like to hear from anyone that has just one drawer. Any issues other than hard corners to bang body parts on? Does it feel rock solid? Or is there some play that a second drawer would eliminate?
I think I will stretch my budget and get two drawers. I want one of each type, but am concerned about noises/rattles.
Any more info on this? I cannot seem to find it on their website.
I googled this:
http://www.equipt1.com/item/weekender-50-52-liter-fridge-freezer-mounting-base-plate
I purchased with fridge at: ColumbiaOverland.com - they should be able to help you find a local rep.
I also use the ARB tie-downs, but i have aircraft track down the length of the drawer on both sides of the fridge and also on the far drawer so I can tie down pelican cases, etc.
Soon, I plan to switch to the AT-Overland combo fridge-slide + stove, and I hear that has a dedicated method for tie-down of the fridge. Another reason I didn't go with the roller top.
I'll echo mcgaskins - I hate rattles, and these don't. I'm sure the gear inside does, but i can't even hear that!
How do you guys manage these when the cargo area is full of gear? Seems like a big hassle and that is why the @TrekboxX solution seems to nice. Can stack gear on top of and to the sides of the fridge with no worry about stuff in the way when sliding the fridge in and out and opening/closing.
A couple of things have reared since I was last in this thread...
- The drawer slide locks are plastic. They break. then the drawer will not "lock" open. I've had 6 replacements.
- Said drawer slide locks only take 25lbs of pressure to release and then the drawers slide closed. Ouch. Any incline and a soft nudge - boom.
- I thought the 3/4 extension would be fine - for the most part it is but, it's annoying. Wish I had full extension, esp. on the fridge slide.
I'm talking to Dave at TrekBoxx about some customizations on System Alpha. I would talk to him before you drop 2 large on the ARB / OS.
http://trekboxx.com/page1/products.html
