Outback control arms
So I'm about to pick up a set of Outback control arms. I understand they correct castor for 850J's with 1 or 1.5" spacers and have read all of Clowmidget's stuff with them on Slee 6" springs . BUT what is the actual degrees that the arms give? Those with the arms, what are you castor readings and with what springs?
I plan to use these with Slee 4" springs and I'm fairly confident they will work without issue. As you know I'm planning on mimicing T Y L E R and running 36 Iroks. He however, used Slee's arms to correct for castor and more importantly push the tires aways from the inner fender because of the wheel spacers he used. If I run into similar issues and need more clearance from the fender, is it possible to CUT the arms and simply add length to them? Will this also effect the castor?
Unfortunatly I don't have caster #s for you, but I do have a set of Outback arms with J springs and 1.5" spacers. The arms were on the truck when I bought it, that's why I never bothered checking caster. I'm certain that the Outback arms will work great. I am currently running 315s but have been considering some 36" IROKs. I anticipate need some wheel spacers if I do that.
personally I would not cut and lengthen the arms, although it could probably be done by sleeving inside the arm. That's just a little sketchy in my mind, to just get it all lined up properly. Seems much easier, cheaper to just use some wheel spacers if you have clearance issues.
Well the issue of rubbing is due to using wheel spacers. Following T Y L E R's build the 36's cleared before he put the wheel spacers on. When he put the Slee 4" springs on he used the Slee arms to push the axle forward. I plan to use 1" wheel spacers and like you mentioned, scketched the idea to sleve the inside of the arms if I tried to lengthen them.
Dump your flares if you want to run 36's on a 4" lift. Keep your stock arms and do the "washer mod" to rotate pinion properly for a DC shaft so you have good caster.
You may be able to sell your flares for as much $$$ as having a shop do the washer mod and you are only out the DC shaft. Keep in mind that any of these arms may leave you with a misaligned front shaft where neither a DC nor the stock shaft are vibe free. It is a fixed ratio setup. The washer mod is a sure bet with a DC shaft from an alignment perspective and way cheaper than arms. But remember that Tyler is using Slee's 6" lift arms that are over rotating the pinion on a 4" lift - you may not get the same thing from the Outback arms.
If you really want to keep your flares, and you are planning to rock crawl I honestly think you are better off with 35's and less restricted travel. Tyler's rig looks sweet, but he's not a hardcore wheeler and I believe he has 3" of bumstop drop.
It sounds like you have function following form in assessing 36's and new arms. Nothing gets the coin flowing like trying to build an offroad used lift around fender flares :grinpimp:
Keep in mind he isn't going to the full slee 6" arms Slee sells now...he may have sourced himself some other arms that are earlier and were built for the J springs and spacers, which is pretty much where the 4" spring sits :)
you give this more credit than it's worth.
It is worth the $500+ you save by not using new arms to rotate your pinion down for a DC shaft, and forgoing the assumption that said arms will give a proper pinion alignment to be vibe free when not part of a kit. Nothing more to me, and nothing less.
Since 80 series front arms have no need of a strength increase, you are only replacing them to rotate the pinion or adjust the wheelbase for tire stuff purposes. I would say that we give that approach far more credit than it is worth - lot of coin to gain "bolt-on" when you aren't even sure of the end result until you've spent the money.
There is nothing worse than spending a fortune on bolt on stuff hoping it will work as you get out of the box - I've probably spent $10K in my time doing this when a simple custom job with the vehicle in the fab shop would have run a few hundred bucks with a known result before incurring the real spend.
But hey, give it a shot, it's only coin :D
Well the thing is I like the look 36 Iroks give and they should be well suited to the 4.88 gears I got. I want my 80 to look fabulous but also function, if I wanted to ditch the trademark flares of the 80 I'd just go buy a 62. I just want to insure that if I'm going to put new arms up front I'll get the correct castor for the springs I plan to run. Like I said, worst case I'll rub and have to pull the wheel spacers, unless cutting and lengthening the new arms isn't an issue. I already plan to trim the rear flare to clear. Bottom line, 36" tires need to fit with a reasonable range of wheel travel and flares are staying.
Are you talking about the arms I am selling?
I can answer your question...the arms WILL move your axle forward, they ARE longer than stock, and they WILL correct caster for a J spring with spacer lift, the OME Comp springs, or the Slee 4" springs. You can also correct castor for a 6" lift with these arms if you press in OME bushings, but I didn't want to do that so here I am with the 6" slee arms on order.
Now, with 36" Iroks on J springs and spacers...you will probably rub at full stuff. It won't be major, and if you space the wheels out from stock it will be worse. The flares will take the brunt of any rubbing with wheel spacers on. If you run stock wheels or stock spec wheels you will rub only when stuffed and locked to one side...not something you want to do anyway.
I can tell you I ran these arms with 35s, J springs, and 1.5" spacers with perfect castor and no issues offroad (I do not run flares). THe PO ran 36" SSRs on the trail and they did rub on the body a bit...not bad, as I mentioned.
Otherwise, if you want to run 36s with no rubbing you have to lose the flares, cut something, or live with it :)
The washer mod as I know it will not get you to where you need to be for a DC shaft. How did you do it?
You know, I am probably guilty of both saying this the wrong way and making a bad assumption. I have OME CC bushings installed and think the washer mod would easily be all I needed to finish the job. Problem of course is I'd want to go back to stock bushings.
I think you would need to do equal parts rotation on both the fore and aft axle mounts. Had a thread on this that I started (link below) and you showed your solution, which is dead on because you are setting pinion perfectly for your lift with everything already installed.
Selling those brackets :D ?
https://forum.ih8mud.com/showthread.php?t=112140&highlight=washer+caster
Maybe I haven't been "in the loop" so-to-speak on the Outback arms that everyone is talking about. Is there more than one Outback control arm design?
the ones I've got were developed years ago (when 80's were pretty new to the trail scene) by Brian something-or-other of Outback Suspensions. These arms that I have were already on the truck when I bought it back in 2001 so I don't have details on where they were purchased. They are similar looking to the original Slee arms but have the wristed joints and the tell-tale shock boot covering the joint.
Is this the same arm you guys are talking about or is there a new one? The one I have is the top one in this photo.
Thanks Adam!! That's kind of a picture I was looking for. I know it's all hypothetical questions I'm posing about the amount these arms will move the axle forward with Slee 4" springs. It's going to end up being a trial and error when I finally put the suspension on and tires.
Dan, I've stood next to your truck before it went to Asia and looked it all over. I thought it had 37" SSR's? From what I remember the front axle centered in the fenders pretty well. Don't worry I'm still going to buy your arms, I just wanted to hear some input here.
Thanks again for the responses guys!
It was Brian Williams. I think that Brian & Slee worked together to develop them. I know they were available from Slee (Christo, if I'm wrong please correct me). Nice arms. As I recall, the rubber boots didn't fare well in the rocks, tho...
Bob, you win the prize! :D Yes, Brian Williams did them on his truck, then we started working together and he was making them and we sold them. Each set was made for the lift per vehicle. It was J springs with 1.5" spacers on that truck. So around 5" of lift.
The slip joint did require maintenance.
We did some like that, then Brian's work situation changed, we started to sell more than he could make. We then took over the design, eliminated the joint due to cost/ benefits. We made the tubular style for some years, and then decided to go all billet on them.
