OME spring install question. What helps
When you take your tires off, stack them up and put them under the frame. If the car falls, it will hit your tires instead of your chest.
I think that was a Slee suggestion, and it sounds like a good one.
good call, I always throw my tires under the frame when I work with them off for added safety. No squooshing da head!
Just got my first Hi-lift.. Got it for the trail.. Only place I could see it be handy is in the rear in conjunction with tall jack stands and a floor jack for the axle. Just not sure how to lift the arb equipped front with a hi-lift.
Doing mine tomorrow afternoon..
I bought extended braided brake lines so I will just remove the old lines at the same time as the shocks and sway links then droopsy do... Have two tall jackstands for the frame that dwarf my other set of 4. One end at a time with the other chaulked, in park and low locked. For the front I am thinking of pulling the wheels off the end I am doing and lowering the axle with the floor jack as low as it will go w/o dinging my new rotors..
Rear looks easier. High lift it with the wheels on untill the springs look like they will come out then put the frame on stands and pull the springs..
when I was in high school one of my classmates was working on his car in the driveway. The family was known not to be the smartest bunch. Well, while he was under the car his brother came over and let the hydraulic jack down. Got his head caught between the rear diff and a cinder block somehow.
The good news is that the dent popped back out :eek:.
I use oversize jack stands, tires go under the frame and I cross my legs if sitting down so they aren't under the truck. You just can't be too careful.
x2 on the crow bar to finesse the springs into place
x2 on having some buddies around
In addition, getting some PB Blaster on the rear shock top nuts is beneficial, but the path to do so is not clearly evident. You can access the rear shock top nuts by attaching the little plastic spray straw to the PB and spraying through the gap over the top of the frame rail (behind the rear tires).
Also, having an extra jack to manipulate the axle was pretty key.
If you find that you don't seem to have enough room to get the rear springs in and out, try using a jack to raise the rear of the vehicle a bit (thus lowering the front a bit using the "seesaw" method on the jackstands). Obviously, use your judgment and don't unweight the jackstands.
One thing I have found helpfull is putting rust remover on threads daily a couple days before hand.. One can also shoot PB on after the last rust remover treatment but I have had many stubborn fasteners become easy after getting hit with an old tooth brush and rust remover a few times..
