OME anti Inversion install issue!!
mattressking
10 digits to freedom
Idaho
Need some help, having trouble installing rear leaf springs on my 60.
Running OME CS017RA on left and right.
Anti inversion shackles don't seem to fit correctly. Any tips? It almost seems the leaf springs are too short. The arrow on leaf is facing the fixed end.
I've tried running the shackles a couple ways but none of the seem to work correctly. Any input?
My shackles look the same right now and I just installed new springs. I believe once you have weight on the rear axle the springs will be compressed and "stretch out" pushing the shackles to the correct orientation.
Did you figure what was happening here? I'm having the same problem.
Vehicle weight has got to be pushing down on the springs for them to flex and flatten out
That's a pretty thick camber correction wedge. How did that map out at alignment?
