Some nice new brake flex lines from StopTech, and the u-bolts and painted plates in place.
Heading the other direction we have the engine with the sequential turbos in place. All hard pipe with needed flex thanks to vanjay clamps (not installed.)
I'm still deciding how I feel about the bulldozer yellow. Pantone 109 was the mix formula. The dark grey and bronze are nice sensible german engine colors, but I wanted to spice things up when it came to this monster intake. The small snail (HE211) is still in primer because I forgot to paint it.... Hot side snails are silver VHT ceramic over VHT primer. I couldn't justify the cost to have them Jett-Hot coated, especially when I'm going to further insulate them. Just wanted something to keep the rust off.
Other side of the intake, the frozen boost air-to-water IC up top, and the stock merc runners welded to a 3" aluminum tube.
Here's a side view of the hexapus blower contraption:
Was really not pleased with how my welds turned out on the small compressor intake pipe, but after grinding them off an redoing them 3 times with pretty much the same result, I had had enough. That tube is too thin (.063 wall) to grind them down smooth without resulting in holes. They were air tight, and that was that.
Lastfully, more progress on the oil-tower relocation. This was necessary to move the engine down and back and clear the brake booster/firewall. Here I've got the AN lines to the block in, including the drain-back line. I used -10 for the main lines, -6 for the drain.
That's all for this week. This weekend I'm hoping to finish the exhaust, including the wastegate bypass, and start assembling the front axle. Once the mechanicals are all bolted back together, I can dive into the plumbing and electrical, which I'm really looking forward too.
