Old warn winch
Value
  • Value
    Votes: 0 0.0%
  • Warn winch
    Votes: 0 0.0%
  • Total voters
Steamboat Springs Colorado
What do you guys think this winch is worth? The motor needs work and it needs a new brake linings, the guy wants $600.00 and it has no controls . I want it for my vintage LV just not sure it’s worth it.
That seems quite pricey, especially with missing parts and needing a rebuild.
But, are there a lot of others on the market to compare it to?
Comes down to what you want to spend and how bad you want it.
$600 for a running 8274 would not be bad. But $600 for a pre 8274, even if it was complete and running would still be too much. He's going to be sitting on that for a while. I would fish around mud a little bit and see what you can come up with.
time and parts will probably put you at 800.00. For 900.00 you can buy a new Zeon 8000 or for about a grand a Zeon 10k.
The 10k pulls almost 80 less amps at that winch's maximum pull ( 8k ). For a bit more the Zeon 12 pulls 160 fewer amps at 8000.
You can trash a battery very quickly with a winch. A good winch should last 20 years. Question is how many batteries will you go through.
I did 21 pulls, at the first snowfall on the mountain near the shop, in one day. My month old yellow top Optima died that afternoon.
I have dual batteries so I made it home on the Die Hard
$50, if you wanted it for a period-correct piece for one of your old trucks.
If you want a functioning winch that will be easy to use, save your pennies for a used 8274.
Those type of winches don't operate with a remote. I think they have cables going into the cab or they can be operated standing next to it.
If you want vintage and IF it was an option for your rig— buy a PTO— will set you back $2500-$3,000 to do everything correct (winch, tranny cover, shifter, etc) but it will be original. If you can’t do that then having period correct (versus vehicle correct) would not matter much to me and I would just buy a new Warn—but that’s just me.
I got a used 8274 for $50 on CL. It looked like it was pulled out of a pond. Cleaned it up, replaced just about everything (motor, brake kit, controller, bushings) and got a sweet decal set from @SMG ! All in Im probably looking at about $500 for the best looking winch on a 40 and know how to rebuild it should I ever need to again
Nearly impossible to find parts for the old Bellview winches. I tried for several years to rehab one and had to give up on it. Warn discontinued parts on these decades ago. The 8274 is a better option and will look great on your LV.
I have that one - paid $150 for it and the original bumper that was an option back in the day - it also came with the control cables so was complete. He didn’t know if it worked and the bumper was bent. But I got it working again and straightened the bumper. Looks cool all cleaned up but I haven’t used it to winch anything. Works though and is very fast. But I agree keep your eyes open for an 8274 (unless you can get that for $50 and want it more for the period correctness). I scored one for my 75 for $150. It is missing the controller and solenoid cover but otherwise is a perfect restore candidate.
