Oily plugs
Portland, OR
f1.5 plugs were all wet, oily black. Stem seals? No smoke from the pipe though. Compression solid throughout.
PCV system issue / Breather / Dipstick Tube loose wiggle out a bit / bad dip stick / Over Filled With Oil past 8.5 QTS o_O
Brings up another question... the oil pressure gauge rises all the way to the H. Is this because of high-mileage oil? We put full synthetic 10w-30 in it.
Brings up another question... the oil pressure gauge rises all the way to the H. Is the pressure too high?
U will have to bench test the gauge in dash & the oil sender unit to find that out Per. the factory service manual
When my valve stem seals leaked, the rig would smoke on startup for a couple minutes.
You can retrofit 3F valve stem seals from an FJ80 on the F1.5 by the way.
They are viton with a spring seal at the top.
You will laugh when you see your current valve stem seals, basically a loose rubber umbrella...
I'm hypothesizing that the oil we put in is too much/too thick and causing too much pressure and the pcv is sucking oil into the carb because of it.....
Agree with those who think that changing valve seals is the right place to start. Its the least invasive. If that doesn't work you are probably looking at oil rings.
A valve job can do this.
