Oil pressure drop
Anniston, AL
It seems that my oil pressure has dropped recently. Im using the smaller toyota filter and mobil 1 10W40. It used to be right below the first bar, now its at the last bar.
and when driving it was above the 2nd bar always, now its kinda in the middle.
What could cause the sudden drop in pressure? Im aware its still under the "normal" range but im worried what could have made it lower? The oil has about 1k on it and its full. Is it just a gauge malfunction? It doesn't make any more weird noise.
What oil where you running before? Different oils can cause a difference
You have smaller filter and thicker oil... most likely oil pump can not get it through the filter. look for big Mobil 1 filter or switch to 5w-30 oil.
Why did you go to 10W-40 ?
The thing is I had awesome pressure a few days ago now it's lower. I haven't changed the oil in it since I first got it. Doesn't burn or leak oil, just a sudden drop in pressure.
My first check would be the crank pulley, if it comes loose the drive gear to the oil and PS pump will slip, causing pressure loss. Have you noticed any difference in the steering assist?
it all appears to be normal
could it be the oil filter?
The oil pressure gauges are garbage. If you saw how they actually work, it would be very clear why Toyota doesn't print numbers on them. They are nothing more than a rod hooked up to a wire that is heated by current, depending on the resistence of ground provided by the sensor. The needle can easiliy get knocked out of position compared to the internal mechanism, which could make the reading off. The sensor connector might be dirty and not providing as much ground as it was before.
If the gauge and sensor are working perfectly, then it could just be the operating conditions. Generally the warmer the engine (and by extension, the oil) , the lower the oil pressure. The lower the rpms, the lower the oil pressure, once the engine is fully warmed up. Could be that your idle is slightly lower than it was before for some reason. This will definately affect oil presure at least at idle. When you noticed the lower pressure at operating speeds, the rpms could have been lower than before due to the speed or what gear the transmission was in.
The outside temperature and thus the engine temperature could have been colder when you checked oil pressure than it is now. Or maybe your engine is running hotter than normal for some reason. Since the stock temp gauge is worthless, it's impossible to tell what temp your engine actually running, as long as it's not overheating, so this is a possibility. An overheating engine or one running very hot, should produce slightly lower oil pressure measurements than a normally running engine in the exact same operating conditions.
These are all possibilities. Actual engine problems (other than running hot) would be far down on the list of possiblities, IMO. Especially with these rigs and that engine.
Good luck.
Now that I think of it this probably happened after I pressure washed my engine. Can someone tell me where the oil pressure sender is located?
thanks a lot for the replies
From the FSM, it is shown on page EG-191 and EG-204. It on the passenger side of the engine, toward the front, under the front most exhaust manifold. There is a wire loom plugged into it. Looks like fun to get at. Good luck and Merry Christmas ! (I'm waiting for the family to wake up so I can stop staring at and start opening the gifts under the tree!).
Also check your oil level. When my oil level needs topping off, the oil pressure gauge will 'read' lower than it usually does. (my engine oil light sometimes also comes on...). I've found both of these indicators are pretty accurate tips that I'm 1 quart low.
How do I really check if it has slipped? Im not really extremely worried about it but also dont want a blow engine on my hands.
:hillbilly:
My 80 has always read like yours. After 250000 miles I dont worry about it any more. ALWAYS check your oil,each week, and temp. Mike
X2 I am at 201,000.
My gage has never read higher.
mine has read the same since I got the truck with 81K. I had my mechanic check it with his pressure tester. Everything was in spec but at the lower end of spec. Had him throw in the oil pump rebuild kit. It made no difference. So as its in spec I have since quit worrying about it.
Long story short, have it checked, or buy/rent/borrow a pressure tester and do it yourself. Specs are in FSM.
According to the pics, You are comparing the gauge reading at 650 rpm (idle) -vs- 1900 rpm which is likely one of your issues.
Mine fluctuates at those levels, not as much, but it is there. You will likely see a fluctuation of the gauge doing this type of comparison, especially warm/hot.
This is normal? I haven't noticed the pressure gauge react like that on other vehicles but I have on my new-to-me 80.
Using these threads to get up to speed. Thanks to all.
Those levels are low, but it's likely the gauge or sender. If it really is low, you have major problems.
I am running the Mobil1 10w-40 right now with a small filter and it reads at the third bar when above 1500 rpm and at the second bar or slightly below at idle.
You need to find out before you damage your engine, or damage your brain worrying about it.
Go safe .. run a mechanical oil press gauge and let us know your oil press readings .. at least 4.3 PSI at idle and 36 PSI @ 3000k rpm
Mine reads similar to that after its warmed up. I use Mobile 1 5w-30 and currently a small Fram filter. I have a couple Toyota small filters from Cdan though that are about ready to go on... just wanted to get 3000 miles through the Fram. Back to topic.... I had never really paid attention to that gauge, but after a run on the freeway, idle pressure showed low like your gauge! I was alarmed and didn't really know if this was normal. I check the oil much more frequently now and it doesnt consume any. Sure I could probably add a little bit and get the gauge to go higher, but I think im well within spec according to the dipstick.
I'll do my filter change today and top off 3/4 of a quart or so to accomodate for the filter oil that is lost and then some.
Bottom line, I think you're fine. If you are worried, adding 1/4 to 1/2 quart might help ya. Oh, and stop pressure washing your engine, yikes! Too much electrical in there, I only clean my engines with rags... no steam, no water from a hose or nozzle of any kind.
