Oil pressure drop
... Sure I could probably add a little bit and get the gauge to go higher, but I think im well within spec according to the dipstick.
As long as your within a couple of quarts of full, oil level has nothing to do with pressure. Changing to a higher viscosity will increase pressure.
... Oh, and stop pressure washing your engine, yikes! Too much electrical in there, I only clean my engines with rags... no steam, no water from a hose or nozzle of any kind.
Using a home type hose even with nozzle isn't going to damage anything on the motor, if your not careful may have to dry the distributor, but that's it. High pressure devices, steam, car wash, pressure washers, etc can drive water past the seals on the electrical connections, but if used with care, no issue.
A few days after I posted this it went back up to normal.
Well almost a year later its gone back down like in the images above. Do yall think it could be related to the weather starting to get colder? It seems to be fine no weird noises and the oil level is full, although its about 200 miles till the oil change is needed(not that its done this any of the other times its due for a change).
Would it matter where the needle goes immediately after a cold start in the morning and at highway speed?? Gots pics of those situations?
Stock gauges are crap...
I put mechanical units in my ex gasser and HDJ81.
Gasser was running 60psi at hwy speeds and the Diesel runs 20 at idle and 40-60 at hwy speeds, gives me lots of confidence considering the diesel stock gauge never went much over 1/4 at any time.
I think someone metioned your crank pulley... I would check into this... I used to have SAABS (Something Almost Always Broken) and the idler pulleys would act up when we had a weather change.
Just a suggestions, hope you nail it down.
Jake
I said I wasn't going to worry about this anymore but I drove my sisters beat up 80 over the weekend and hers read like my used to. I would like to think that mine is in much better condition than hers, she has got about 40k on mine and mine has been maintained which hers hasn't.
Ambient temp:49
engine temp:186
Oil changed last week with mobil 1 10w40 with a toyota small filter.
start up:
warmed up:
1500rpm:
3000rpm:
Tomorrow is my last day before turkey break and I plan on addressing this issue during my time off. So I need to check the crank bolt, try to buy a oil pressure gauge, and is there anything else to check?
Is a aftermarket oil pressure gauge hard to install? Can I keep the one hooked up in the instument cluster?
Try and swap senders with your sister. That would take 5 minutes. If you then get normal readings, you have your answer.
I don't know where you are, but I have a test gauge I'll send you if you promise to use it and send it back.
Looks just like my truck (Rotella synthetic 5w40 and the big old Toyota filter). I haven't hooked a pressure gauge to it, but I think there is a reason the gauge operating ranges in the owner's manual are so large. The stock oil pressure gauge is pretty vague.
Both of those options would be great, but my sister lives 2 hours away and has gone to her husbands family for thanksgiving, and it seems I live on the other side of the country. IDK if you would like to send it that far away. I'll pay all the shipping if your down for sending it.
How much would I get charged to take it somewhere and get the oil pressure tested?
lndcruz,
Mine looks very similar to yours, if not a bit lower during startup. I recently changed to 10W-30 from 5W-30 and have been running the small synthetic Toyota filters. When I did the oil change, my pressures seem to be up slightly overall (i.e. they were even lower than your pictures show).
I recently had an incident with my oil sending unit where I broke the wire by stepping on it. If you are really concerned and want to mess around with different senders, the unit is not that hard to get to. I believe I released the harness clip with a flat screw driver and was then able to solder the wire back to the metal piece of the clip. I performed the soldering inside the engine bay near the connection without much trouble. Of course, it would have been easier if I were willing to clip the wire somewhere to remove that section from the truck to perform the soldering, but I didn't feel like cutting anything.
The startup pic looks too high, and the warmed up pic looks too low. The startup pic would be where my gauge (in either truck) would be when under throttle or cruising. The warmed up pic is where it would be if it was off.
I would also guess a bad sender unless you are hearing noises when the oil pressure is bottomed out.
in my wife Cruiser the cold startup reading looks the same .. but when she warmed up it never fall under the middle of the gauge ..
but I never trust in Toyota factory gauges .. so I take measurements with a mech gauge and all readings looks normal .. and that's what I recomend if you are concern with your oil press readings ..
Yeah, no weird noises. Im going to try to clean the connections on the sender and see if that clears anything up.
When my engine is off and the ignition is on its a little lower than the last bar.
I have the same issue, I services my LC 1HD-T, with the same oil and oil filter, when I was driving I saw the oil pressure is way below normal... I also cleaned the engine with a high pressure... wonder what it could be?
Mine was reading at the very bottom as well, which is in spec but wierd. I changed my oil to castrol syntec 5w30 full synthetic. it now never dropping below 1/8 on the gauge. doesnt burn or leak any oil for the past 15k miles.
