Bumping this one.
@SummitCruisers Jr,
I also have a 3FE FJ80 (1991) and wanted to do exactly what you’re doing. Had a couple of questions:
- Did you switch from OEM lockers that were previously retrofitted to your rig? If so, why did you switch from OEM lockers to Harrop elockers?
- What was your concern about not wanting to hack up your gauge cluster to add the OEM front and rear diff lock indicator light strip at the bottom of the instrument cluster? I spoke with a mechanic and he seemed to indicate that it was “relatively” easy / minimally invasive to swap in the bottom strip OEM diff lock lights from a 93 or newer instrument cluster.
First time poster, long time reader. This is a great forum!
Welcome to mud! No, I didn’t originally have factory lockers. I bought a set of locked axles from a junkyard but it ultimately wasn’t going to be worth swapping them in considering the issues that they can develop. I sold them and bought an unlocked full float rear axle from a ‘95 to swap in with the harrop and gears.
Here’s a pic of the back of a cluster from a ‘97. If your mechanic has done that type of work before, I’d be interested to see how that would be done. I personally don’t see a way how that would be done cleanly, and in an OEM looking way.
