OEM parts
Old Fort N C
I,m looking for a couple of things to push my project on down the road.
Engine is out of a 86 FJ60, but I think anything 2F would work.
1) The metal fuel line from the carb to pump ( there is a short rubber hose mating the two I think).
2) Tab washer for the harmonic balancer nut.
Called my two local dealers, they had no clue, Matt at Ventage doesn't have it, and I have no idea how to contact Beno.
Any help would be appreciated, I'm trying to find time to start a build thread.
Frank
1 depends on what fuel pump and carb you are running
2 later 2F's didn't have a tab on the crank nut, which crank nut are you using?
i have a NOS 8/80-later FLANGE NUT style , NO CLAW washer required , if @3_puppies gives his blessing it will work with a
early balance ? pulley i will sell it to you
i honesty don't know enough about this topic to advise , he is our resident expert so his say is Teq LAW ..........
i dont just off parts to folks , i have standards if i dont know i say so ..........
the nut @ToyotaMatt posted is the later crank nut, and didn't have the provision for the hand crank,
the nut that you could use the hand crank on had the lock tab
will they interchange ok on the pulleys ?
Since Beno has seemingly retired, I would direct you to Toyota South Atlanta-contact Kyle Edwards-parts director--a very helpful individual-they also offer discount to mud members
@JDNs78FJ40 That looks right, my fuel pump has hard lines without threads tho. FSM should be here in a couple of days, I'll check to make sure I have the right pump. Thanks so much, I'll DM you when I know something.
