Soooo. I've had a slight steering wobble since installing new front brake rotors about 6 months back. (Also rebuilt front axle at this time) Yes, I broke in brakes after install...The wobble has gotten worse...flat out shakes the whole car violently when brakes are lightly applied. Seems oddly intermittent, but frequent. Maybe just an issue when brakes are warm? Definitely gets worse when car is loaded with 6 middle school guys... The wobble seems to dissipate when hard braking is initiated. I don't see any heat spots on rotors. For the record, the rotors are O'Reilly Auto el cheapo's.
I rotated tires to see if it could be a tire balance issue. No such luck. While I had the tires off I checked for play in bearings...found none. When spinning the rotors, I felt a slight, intermittent drag. I removed hubs on both sides to inspect the tightness of the wheel bearings...everything looked great. Spun both of the rotors with hubs off and they were both smooth as butter...re-installed hubs and the intermittent drag was back. both wheels...
What could this be? Are my problems related? Perhaps not. HELP!
