Not another 1FZ turbo thread!
OffGridOverland
Overland Anywhere - Anytime
Litchfield Park AZ
Website
www.offgridoverland.com
Not another 1FZ turbo thread! USA market anyways.
Well I had my 1FZ eat some main bearings. So its time to rethink stuff here.
Doing a 6BT swap
  • adapter kit $4500
  • 6BT used $2000
  • Another $1000 for here and there parts.
  • Not factory (smog issues)
So this brings that to roughly $7500 without labor.
The TRD S/C kit:
  • Rare
  • Runs hot
  • Pricey at $7500 for a kit
$7500 without labor. Then add $$ on top for cooling parts.
Toyota 1HD swap:
  • Too expensive
  • Too rare
  • Too hard to get repair parts
GM LS* Swap
  • Lots of fab work
  • not a direct bolt in swap
  • $4000 for LS parts
Does this seem to far off? I started this so to head off the swap crew. I've thought about it. I know I can build a quality turbo kit for much less. And now that I have to rebuild my motor. I can build it to my specs.
The key parts for a quality turbo kit
  • Header / Manifold (still open)
  • Turbo (Borg Warner EFR)
  • Intercooler (Garrett custom core)
What is the market for a quality kit. Not the CX racing quality.
For a stock motor I know we have closed to open loop fueling issues, max boost of 8-10 psi.
What is everyones thoughts. And yes I have used the search button. Yes I have read thru everyones builds. I've really only liked one. But still didn't like a few points with it. (I have built more then a few turbocharged subarus at my shop.)
Calculate rebuild costs of the 1fz-fe, this includes new oil pump and waterpump drop compression a little new Pistons new rings.
My opinion fab a decent turbo header. J- pipes create serious heat.
Well I am not sure where else you could plan on packaging the intercooler. I wanted A/W for the slow speed benefits, not to mention I could not do A/A because my winch in the Slee is not the recommended winch so it sits back into the grill and the grill had to be cut around it.
I have had no issues at all. Only time I had heatsoak and that is a pretty loose term is when I was driving 2700 miles across the country and holding the truck around 83mph in high 80's weather I would see intake air temps up around 105F. If I slowed down to mid 70's intake temps came back under 105. And 105 is not bad it is just where I have my water/meth set to trigger when boost is 2psi or above. I am sure the fact my water tank is 6+ gallons helps.
Truck gets driven a lot, sees boost a lot, sees 100+ degree temps in Texas and VA, was in 20 degree temps in Moab. over 450hp and 600ft/lbs of torque and not a single problem.
I wish I had intake air temps like that. Mine normally runs 130* and had it to 150* on the freeway in 90* weather.
I recently had it at 163* in 4low coming out in the hills from the beach. It seems to correlate with my water temp temp 205* Dunno if the cooling fan is pulling so much hot air off the radiator it's making my bay real hot thus sucking in hot intake air and compounding it.
I think SR approach is good with the inter cooler. Cause you need as much surface space on the radiator and with winches it will effect cooling.
Also I just did my head gasket and newer radiator and blue hub with 15k so my cooling system is pretty good.
Also Scott are you running a snorkel?
@Rwhat No I am not running a snorkel I am just running a green filter with a prefilter behind the passenger headlight. My water tank sits where the snorkel would sit. I did have Marc build a "heat shield" into the filter mount to try and keep engine heat away.
This is an old picture and I have made some changes since, but this shows the intake position, etc.
image-1532510973-jpg.780142
LS ALL THE WAY. Anything less is just a driving compromise :-)
Whoa, an LS is a pretty good motor, but I would definitely say pulling a rock solid I6 out and putting an LS in is the compromise. I mean what do you want? Easy parts availability? Lighter weight? More compact size? Easier tuning options? Who wants that??!? JDM Yo. In all seriousness it is 6 in one hand and half a dozen in the other. Just depends on who you are.
Be different and swap in a Duramax.
I REALLY want to see this happen.
Contacted Marks' to ask why they don't have a kit for it.. they said the Allison is too big. The one they did finish used a Dmax out of a van with a 6L90E and even then they had some issues.. but got it working. We arguably wouldn't need the Allison anyway.. or at least I don't plan on towing 20k pounds with my '80
But to hear that turbo spool on the freeway? wow.
Theoretically you could use the Marks bellhousing adapter to bolt the Duramax up the the stock trans. Not sure I'd want to be the first one to test that although the stock trans seems to stand up the a 6bt just fine.
I wonder how hard it would be to make the Allison fit, 1'' body lift and BFH maybe?
When the motor dies in my 80 I'll be swapping the 4.8 Ls with a 4l80. Better mileage with a Ls no matter how you look at it I get 23mpg with the 4.8 I drive for work
We need an adapter for the Dodge Cummins Aisin 6spd to the Toyota case
Marks said it was far too big for our little transmission tunnel..
Sounds to me like turbo 1fz all the way, in your case especially since you are familiar with turbo setups.
