No feedback from Tattons MUD help required please.....
Silvan, Austraila
Hi guys,
I have a Tattons DC front shaft on my manual FJZ80, works fine no problem there. Doing some regular PM and was greasing under the truck, slip joint seems to be taking grease 'very' easily' hmmm.
Next thing grease is leaking out of the slip joint at the lower uni end, slip my finger in there and there's no cap on the hollow tube to keep dirt out of the slip and grease in. I must have over greased it, as you do, and popped whatever cap was in there previously when the driveshaft compressed. I've emailed Tattons for either a size of whatever goes in there or a replacement but weeks later its crickets.
Not keen on leaving the shaft open anyone able to chime in for what blanks off the tube end of the spline at all ?
Cheers. But not for Tattons, not seeming to care about after sales care on a shaft on the other side of the world !
Cant- its an open hole on the back of the uni joint 'arms' that goes into the slip joint no need to cover the slip joint.
Covering the slip joint still leaves the open hole.
Its like it should have welch plus in the hole or similar. If you over grease the shaft it pops out.
That's what I was hoping someone would know :-)
I emailed them a while back regarding a driveshaft, no answer but I know many members here with a good experience with their product.
I was in the same boat. He sent me me a driveshaft with the wrong bolt hole flanges.
Curtis from Tatton will not answer emails unless you are placing an order.
I had to call him everyday for two weeks. It wasn’t a fun experience.
Next time I will go through Tom Woods.
Good luck,
Good luck,
They both use chinesium in there shafts. Use a local shop so you have more control over what you get and better, in person-face to face customer service. I don’t know how you guys can do a mail order driveline in the first place.
I recently bought a Tatton rear DC driveline that had a DC joint failure on the highway. Posted the incident here.
Tatton DC Failure
So I HATE getting involved with any competitor discussions because its very easily seen as self-serving BUT I am chiming in because I just want to share a little bit of info. I have spoken with my fair share of individuals concerning their DC Shaft needs and unfortunately I have now seven former Tatton shaft customers who have switched out to the LANDTANK DC shaft. That is seven that were forward with that info. Guys there is a reason why LANDTANK starts with a stock Toyota shaft and that is to prevent these issues.
