Newfield, Warranty Them?
Sounds like your getting your moneys worth out of them.
Longfields, newfields, etc. are sifter and are more resiliant off road, but wear fast on road.
If you do mostly on road, then you should go with a Toyota Birf
Or, replace with another newfield, longfield, superfield, sleefield and do a 2wd conversion to prevent wearing those much needed offroad components doing asphalt miles?
Or could always go back to stock birfs meant for daily driving.
Called Newfield and they ONLY warranty for breakage not wear.
They said I could send them in to be checked by owner and they might replace them?
Guess I could just install the hubs and drive shaft and drive till they break ;)
Not having broke a birf, is the only way you to know if you brake them is if the wheel turn free from the axle or can they brake and still lock up the axle to the hub?
These would still wear faster than a stock one.
If you let them break, they could cause other damage within the knuckle.
If you just did the whole front axle rebuild 40K ago, you could replace the birfs whithout removing the knuckle or doing the trunion bearings. Might as well replace the inner axle seal though.
Usually you will hear and feel metal on metal crunching rotationally, and binding in steering. Depends on how badly the break is. If you only crunch the bearing cage it will sound terrible and bind up in turning.
If you break the bell you will know it...steering and everything will be much impacted.
I suspect that unless you wheel it hard a mild break (cage, etc) will be the issue due to wear over time.
Romer, they are actually softer. This gives them the ability to twist without snapping. But also causes them to wear faster. ;)
I have no clue why someone would run these on a DD or any rig that sees a lot of road time. They are for hard wheelin'. You should put stock birfs in. Now the axles are a diffrent story.
Thats what I said. I see the typo sifter. was suppose to be softer and not stiiffer:D
<<<I have no clue why someone would run these on a DD or any rig that sees a lot of road time. They are for hard wheelin'. You should put stock birfs in. Now the axles are a diffrent story.<<<
When I got them 5yrs ago I don't think it was known what these were for nor did anyone know that they going to wear out fast. At least it was not known on the MUD.
Where were all of you 5 yrs ago when I was having all my problem that are now common known easy fixes :flipoff2:
Well that sucks.... and I almost had myself persuaded that it will work out.
Buy the super set once and then just replace the birf when it wears out. $300 every 40K miles... That's a no brainer. Now if you have them and don't need them (don't have large tires, don't wheel it hard) then you are wasting money. Even then, for a little perspective, just your oil changes are going to cost way more than that.
Kyon
Well, I don't have to break them...
I pulled the birf and it was broken already. I thought the noise was more than a pop.
Some of the bearing were sitting in the housing.
The cage is broken and the inner star is damaged.
I will see if its still under warranty.
The answer is quite simple...........$
Stock birfs list for well north of 600 bucks a rattle and the short-sighted billfold prefers the cost of the aftermarket pieces.......
It is strange that they broke when turning off the freeway on an off ramp. I thought they don't brake???
What Birf to get:
Well, if you drive hwy lots and wheel hard, what do you do?
OEM birf, last long but break when wheel hard.
Otherfields, don't break (well shouldn't) but wear out.
I will take the not breaking over long wear.
You have to wheel "Christo Slee hard" to break a stocker. Your tires are not anywhere large enough to be an issue.
