Newby intro and a question
Tremonton, UT
About three years ago I went wheeling with a group that included Shawn Jackson (Action Jackson). I was only a rider at the time but figured that if I was ever going to get a 4X4 I would like it to be a LC ;). Since then, I’ve been looking for one on and off. One day this last April, my brother called to tell me he found the “perfect land cruiser” for me. I called the PO and he said I could come look at it but that someone else was also interested. At 9:30 p.m. my :princess:, two kids and I loaded into the minivan to go look at the LC. I ended up buying the LC that night (at 11:30) on somewhat of an impulse since I didn’t have access to a mechanic that late at night. I think I got pretty lucky though since I haven’t seen any evidence of major problems :D. The details are as follows:
94 w/ front and rear factory lockers and 90K miles
ARB front bumper with 10000lb Warn winch
Kamar rear bumper with spare tire and jerry can swingouts
2.5” OME lift and 287/75/16 BFG A/Ts (not good in mud!)
Custom sliders and 35 gal aux gas tank
Safari snorkel to feed the Kazuma S/C :cool:
All for $9600 (the LC was stolen at some point and has a salvaged title)
Here are some pics from when I brought it home:
Since making the purchase I have replaced the scoop for the snorkel (missing at time of purchase), rebuilt/serviced the front birffs (thanks to the FAQ), changed the diff oil, replaced the OEM fan clutch with the blue hub version, modified the stock temp gauge (thanks to the FAQ here also) replaced the entire exhaust after mutilating that tailpipe sticking out the back :doh:, added a few pinstripes, cracked the rear flare (Hells Gate in Moab :doh: again!) and removed the aux gas tank (hung down too low reducing my clearance). Now I am in the process of adding the CDL switch. (Did I mention that I’m now broke! :o) Thanks to CDan for all the parts!
Now for the Question.
I’ve run into a problem after installing the CDL switch. When I push the newly installed CDL switch, I don’t get any diff lock or ABS lights on the dash. As a result, I can’t engage the lockers :crybaby:. This is the case in both H and L. Last weekend I was wheeling and used all three lockers without any problems so it seems like adding the switch caused the problem. Any ideas??
I did search and found some info regarding the center diff lock indicator on the Tcase but was wondering if just adding the CDL switch would affect a previously working CDL indicator. Is the CDL indicator where I should start?
Did you do the 7-pin mod when you installed the switch? If not, then I'd double check that the switch is fully plugged in. I believe that the CDL would be inoperable via shifting to low range if the jumper wire on the dash plug was removed, as you would have done before installing the switch. If you don't find a problem at the switch connection, take the switch back out and re-install the jumper wire, see if you can get the CDL to lock by shifting to low range. If so, concentrate on the switch and connection to find your problem.
If you did the 7-pin mod (disconnecting a wire under the dash to give you more control over the CDL, you'd know it if you did it) then you might have disconnected the wrong wire. Removing the switch, re-installing the jumper wire and shifting into low range will not engage the locker, then it's a matter of confirming that you did the mod correctly.
-Spike
Thanks.
When I bought the truck the PO said it didn't pass emissions and was probably the MAF sensor and took $200 off the price. Unfortunately it was cracked head pipes and a bad cat instead:doh:. Much more than the $200 credit but did force me to get a high performance cat and go 3". I still think it was a great deal.
Spike -
I did do the pin 7 mod at the same time. I printed out the instructions from Slee so I'm pretty sure I got the right wire. Also, after putting in the CDL switch, but before doing the pin 7 mod I tried the switch but got no lights on the dash. At the time I thought maybe it was because the engine wasn't running. I guess I shouldn't have buttoned everything back up :doh:. I was installing the switch at night and I do have the back light so the lettering on the switch shows. I'm guessing that means I have power to the switch. Yes or No?
EDIT - Is there any way to get the CDL switch out safely without removing the dash again?
Thanks.
Spike -
Could be the switch. I think you could use the hazard switch as a CDL switch to check it. With the mounting tabs the way they are, I would worry about breaking the fascia on the center console. If I were you, I'd take it all apart again, and replace the CDL switch with the hazard.
Edit: never mind. The hazard switch isn't the same on the 93-94's. Does anyone know if the ECT switch will work in a plug and play?
great steal, uh i mean deal. welcome:flipoff2:. enjoy your new toy.
cheers.
There is a jumper your suppose to remove I think, did you do that? Double check the switch to make sure its seated, that would be my guess. If it is,swap it with the Hazard as suggested and see what that does.
The other thought is you may have blown the fuse or the connector at the tcase came undone.
Feeling kind of dumb now. I got home from work, was able to get the CDL switch out of the dash without breaking anything and it was connected correctly. I then thought to look at the 30amp fuse for the diffs and sure enough it was blown :whoops:. Not sure how/why it blew but after replacing it, the CDL switch and 7-pin mod seem to be working correctly. I'm gald it was a simple fix, just should have thought of it earlier.
Anyway, I guess at least it got me to my first post in MUD :D.
Thanks for the suggestions and sorry for the newbie resolution.
Also, here is a pic from my run this last Sat. It was raining and I thought I would try and straddle this ditch. Unfortunately I slid to one side as a result of a combination of mud, BFG A/Ts and driver error :doh:. At least I was able to back out of it w/o any body damage ;p.
Awesome.
Glad it worked out. It's those simple things that get everybody. Fuse's blowing are always overlooked unless you see a spark.
Everybody does those things that make them feel stupid. I busted a rdaiator changing a spark plug leaning on the nipple on the top.
