RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
I think with all the info collectively on this entire forum or what I call the offroad BIBLE, we need to start a how to keep your rig rolling thread.
Ill start: ALWAYS keep your fluids clean and topped off. And always grease your U joints tie rods and other zerks
Always carry spare belts,plugs and U joints when Overlanding .
And heres the factory maintenance schedule for a 97 lc fj80
1997 Land Cruiser 15,000 Miles - 12 Months
Replace engine oil and oil filter
Lubricate propeller shaft and re-torque bolts (4WD)
Lubricate steering knuckle
Rotate tires
Inspect the following:
Automatic transmission and differential oil
Ball joints and dust covers
Brake linings/drums and brake pads/discs
Exhaust pipes and mountings
Steering gear box for leakage
Steering linkages
Additional Maintenance Items for Special Operating Conditions:
Driving on Rough, Muddy or Snow-Melted Roads
Inspect nuts and bolts on chassis and body
Driving on Unpaved or Dusty Roads
Inspect engine air filter
Towing a Trailer or Using a Camper or Car-Top Carrier
Replace automatic transmission and differential oil
1997 Land Cruiser 30,000 Miles - 24 Months
Replace engine air filter
Replace engine coolant
Replace non-platinum spark plugs 1
Lubricate drive shaft bushing
Repack front wheel bearings
Rotate tires
Drive belts (non-ribbed)
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
Fuel tank cap gasket
Steering linkages
Transmission, transfer and differential oil
Replace transmission, transfer and differential oil
Applicable Footnotes:
1) Required under the terms of the Emission Control Warranty.
1997 Land Cruiser 60,000 Miles - 48 Months
Replace spark plugs 1
Rotate tires
Charcoal canister 2
Drive belts
Engine valve clearance
Steering linkages
Valves (audible inspection), adjust if necessary
2) Inspect at 60,000 miles or 72 months, whichever comes first. Required only for vehicles in California, Massachusetts and New York.
1997 Land Cruiser 90,000 Miles - 72 Months
Rotate tires
Drive belts
Steering linkages
1997 Land Cruiser 120,000 Miles - 96 Months
Rotate tires
Charcoal canister 2
Drive belts
Steering linkages
2) Inspect at 120,000 or 144 months, whichever comes first. Required only for vehicles in California, Massachusetts and New York.
Maintenance Definitions
Automatic Transmission Fluid
Inspect or replace at specified intervals. When performing inspections, check each component for signs of leakage. If you discover any leakage, have it repaired by a qualified technician immediately.
Ball Joints and Dust Covers
Check the suspension and steering linkage ball joints for looseness or damage. Check all dust covers for deterioration and damage. Replace any deteriorated or damaged parts. A qualified technician should perform these operations.
Brake Lines and Hoses
Visually inspect for proper installation. Check for chafing, cracks, deterioration and signs of leakage. Replace any deteriorated or damaged parts. A qualified technician should perform these operations.
Brake Linings/Drums and Brake Pads/Discs
Check the brake linings (shoes) and drums for scoring, burning, fluid leakage, broken parts and excessive wear. Check the pads for excessive wear and the discs for runout, excessive wear and fluid leakage. Replace any deteriorated or damaged parts. A qualified technician should perform these operations.
Charcoal Canister (CA, MA and NY Vehicles)
Check for internal damage and clogging. If necessary, clean with compressed air or replace. A qualified technician should perform these operations.
Differential Oil
Replace at specified intervals. When performing inspections, check each component for signs of leakage. If you discover any leakage, have it repaired by a qualified technician immediately.
Drive Belts
Inspect for cracks, excessive wear and oiliness. Check the belt tension and adjust if necessary. Replace the belts if they are damaged.
Drive Shaft Boots
Check the drive shaft boots and clamps for cracks, deterioration and damage. Replace any deteriorated or damaged parts and, if necessary, repack the grease. Selected models also require periodic inspection of the driveshaft bolt for proper torque. A qualified technician should perform these operations.
Engine Air Filter
Replace at specified intervals. When performing inspections, check for damage, excessive wear and oiliness, and replace if necessary.
Engine Coolant
Drain and flush the cooling system and refill with ethylene-glycol type coolant. Inspect the radiator and condenser for leaves, dirt and insects and clean if necessary. Inspect hoses and connections for corrosion and leaks. Tighten connections and replace if necessary. A qualified technician should perform these operations.
Engine Oil and Filter
Replace the oil filter and drain and refill the engine oil at specified intervals. For recommended oil grade and viscosity, refer to the Owner's Manual.
Engine Valve Clearance
Inspect for excessive lifter noise and engine vibration and adjust if necessary. A qualified technician should perform this operation.
Exhaust Pipes and Mountings
Visually inspect the exhaust pipes, muffler and hangers for cracks, deterioration and damage. Start the engine and listen carefully for any exhaust gas leakage. Tighten connections or replace parts as necessary.
Fuel Lines and Connections, Fuel Tank Band and Fuel Tank Vapor Vent System Hoses
Visually inspect for corrosion, damage, cracks and loose or leaking connections. Tighten connections or replace parts as necessary.
Fuel Tank Cap Gasket
Visually inspect for cracks, deterioration and damage and replace if necessary.
Nuts and Bolts on Chassis and body
Retighten the seat-mounting bolts and front/rear suspension member retaining bolts to specified torque.
Propeller Shaft
Lubricate the propeller shaft spiders and slide yokes with lithium-base chassis grease and the double cardan joint with molybdenum-disulfide lithium-base chassis grease, and re-torque the bolt. Only a qualified technician should re-torque the bolt.
Radiator Core and Condenser
Inspect for debris and signs of damage. Have any problem repaired immediately by a qualified technician.
Spark Plugs
Replace at specified intervals. Install new plugs of the same type as originally equipped. A qualified technician should perform this operation.
Steering Gear Box
Inspect for signs of leakage. If you discover any leakage, have it repaired immediately by a qualified technician.
Steering Knuckle Grease
Repack the Steering knuckles with molybdenum-disulfide lithium base chassis grease. After submerged, be sure to apply grease within 24 hours regardless of the maintenance intervals.
Steering Linkage and Boots
With the vehicle stopped, check for excessive freeplay in the steering wheel. Inspect the linkage for bending and damage and the dust boots for deterioration, cracks and damage. Replace any damaged parts. A qualified technician should perform these operations.
Tire Rotation
Tires should be rotated at specified intervals according to the instructions in the Owner's Manual. When rotating tires, check for damage and uneven wear. Replace if necessary.
Transfer Case Oil
Inspect or replace at specified intervals. When performing inspections, check for signs of leakage. If you discover any leakage, have it repaired by a qualified technician immediately.
Wheel Bearing and Driveshaft Bushing Grease
Repack the wheel bearings with wheel bearing grease and the driveshaft bushing with molybdenum-disulfide lithium-base chassis grease. A qualified technician should perform these operations.
Please chime in. FJs are a special animal and some of us own them and need to represent them well. JMO
RFB
Rotate tires
Steering linkages
Rotate tires
Steering linkages
Rotate tires
Charcoal canister 2
Drive belts
Steering linkages
Rotate tires
Drive belts
Steering linkages
Rotate tires
Charcoal canister 2
Drive belts
Steering linkages
Differential Oil
Drive Belts
Drive Shaft Boots
Engine Air Filter
Engine Coolant
Propeller Shaft
Spark Plugs
Steering Gear Box
Tire Rotation
Transfer Case Oil
RFB
