Build New project, 1969 fj40
Is that not the cutest little thing? 🤣
New bling from VintageTEQ.
On the left is the bolt(s) that came with the water pump a couple years ago, from a well known cruiser ‘store’. On the right is the bolt(s) that came in the ‘OEM Water Pump Bolt kit for ‘74 and earlier Land Cruiser FJ40; from a different well known cruiser store. (They’re the same length.)
Then the pic of how much is exposed, to go into the block.
I get what y’all are saying about them needing more engagement, but this is apparently factory.
What's the condition of the threads at that depth? Are the new bolts sloppy at that depth? Does the bolt engagement get better deeper in the hole?
What's the condition of the threads at that depth? Is the new bolts sloppy at that depth? Does the bolt engagement get better deeper in the hole?
Two of the ‘short bolt’ holes were fine, as was the long one. I can thread a bolt in the ‘bad hole’ by hand farther in than it goes when bolting up the water pump, but for some reason the threads on the bolt get messed up when bolting the water pump on.
I’m waiting on a bottoming tap or whatever it’s called to clean the bad threads (they’re fine with my tapered tap) and try again.
They all held for a year and a half, the bad one just started leaking the last time I started it up.
A thread restorer and a bottoming tap are two totally different tools. Taps cut threads, restorers will clean existing threads and "push" any distorted thread back into place. This is if your block holes have some minor damage. If it's just dirt in the hole, a wire brush, brake clean, and compressed air is all you need. If the restorer won't thread in, you may need to use a tap to cut the first few threads clean. I would not bottom a tap out in that hole, you will have a poor fit.
As far as the bolts go, the shortest stock bolts are 35mm in length. There is also a longer bolt listed on the parts diagram, appears to be 10mm longer. Since the face of the block where the pump mounts is a flat plane, the water pump casting is where the length variance comes from. When attached, each bolt is at the same depth in the block. You can easily gauge the depth of the block holes by using a bit of wire, brake cleaner straw, etc. The bolts you have, with the water pump you have, are insufficient. Measure the thickness of the water pump where the thru holes are, add 15 mm, and add the thickness of your spring washer. This is approximately the bolt length you need, at a minimum. Now measure the depth of the block holes, the thickness of the water pump at the thru hole of interest, add the thickness of the spring washer, this number is the maximum length of your bolts.
If you have half the thread engagement that's required, at the specified torque, your doubling (plus) the stress on the threaded connection. By using a bolt length to better match the hole depth (threaded grip) you're spreading the stress evenly across the gripped parts.
I hear you, but this is good info for the ‘OEM bolt’ Cruiser parts suppliers too, I guess because that’s where these are coming from. Two different Cruiser shops that supposedly know their stuff sent me the same length bolts for this application.
What water pump brand are you running? I've ran into some wild fitment issues with aftermarket junk. I won't name any names, cool cruisers of... Could it be the casting of your pump is thicker than stock?
I got it from a cruiser supplier (with the bolts). I’d have to look I just assumed it was oem/rebuilt.
Went to remove the skid plate to change the transmission/transfer case oil and the front right bolt just spins. I couldn’t really feel up in there from where I was but I doubt it’s a welded nut?
I don’t mid grinding off the head, but fixing it is going to be fun.
