New F & 2F carbs
Awesome, when would be a good time for me to drive up to get one? Also, how much will the total be considering no shipping? Thirdly, does anyone make a decent header for these?
Just call before you come. 8644140563
Total is 230
I realized it would be more expensive in gas to drive to Mauldin than it would to ship. However, I really can't use PayPal. Would you mind PM'ing me your address and I'll mail you a check, and you can ship it once you get the check? Thanks.
I have shipped all carbs that paid before Oct 26th. The rest will ship on Monday. I've unpacked inspected and tested almost 75 carbs in the past two week.
Thanks everyone for being patient.
I also have carbs in stock and most likely will through the end of the year. Another batch should be coming in early January and I'm planning on not being out of stock next year.
my carb arrives Monday, i plan on replacing the intake manifold gasket and replacing the thermostat at the same time , i will post up how it turns out, i still have to have the dizzy recurved
Do you ship to canada? If so quote to postal code N1M2W7
Thanks Graham
Yes I ship to Canada. I ship through USPS for Canadian customers.
USPS which is all inclusive is
Express Mail® International
3 - 5 business days
$46 additional
Priority Mail® International
6 - 10 business days
$27 additional
Do you have any Dizzys available? If so whats the price on one for a 87 fj60?
You don't want my dizzy for a FJ60. Look in my used parts thread. I have used FJ60 dizzy for sale.
Ive got a 9/71 with a 4/72 motor and carb and the New trollhole carb has been the best money spent so far, i bent the throttle cable plate to clear the capped air rail and adjusted the idle and it's starting instantly and running without any hesitation now, I couldn't be happier. I had to cut the front passenger side shaft to clear the PCV hose and bend the steel fuel lines to fit the different configuration.
It's a totally different ride now, I'm assuming the secondary on my stock aisin carb wasn't even functioning as I was topping out at around 50mph and now it wants to just go and go. The real test will be how easily it starts after sitting for a few days. Can't wait to throw the starting fluid in the trash and have a vehicle that reliably starts evey time.
i took my rig out wheeling to at about 6000 ft level and the carb was not happy, stalling ,strong odor from the exhaust it idled at about 200 rpms lower than it idles at the altitude i live at, by chance am i running with the sea level jets installed, are the jets labeled so i can tell the difference.
Look under the fuel bowl and see if there is a rivet painted red.
Call me tomorrow afternoon. And I'll help troubleshoot with ya.
8644140563
i called and left a message, i found a rivet on the drivers side of the carb below the float bowl level, it is not painted i am assuming that means the jets have not been changed out, i have Thursday off i will give you a call before going any further
I am all set to order one of these carbs from you I hear great things about them I just have one question to make sure I get the right one...? I have a 1976 2f with a jerry rigged Holley carb on it now (have to squirt gas in it to get started). I don't want to get confused between mechanical linkage type and throttle cable type. I think my set up is stock but not sure 100%..? I have a cable running from my pedal to a bent up jerry-rigged bracket on the carb. I was not sure if mechanical linkage meant just near the carb or all the way from the pedal...? If you could please let me know which one fits my needs I would be grateful. I am hoping to order it ASAP! My rid is de-smogged and I've no intention of smogging it again I am in a rural county where I don't have to smog it for tags. Also run a Pertronix Electronic Ignition. Thanks in advance. Any way to call you?
I found my carb answer here Mechanical linkage. Anyway I just ordered a carb from you RECEIPT # -4100. Was wondered if there was any chance of it getting here/CA in the next week or so hopefully before Thanksgiving..? Have time to put it on then! I will pay for any shipping to get it here by then. Please let me know if you get a chance. Much thanks in advance.
Ships tomorrow. I worked all last night getting vendor orders out. It normally takes 5 days to get to CA. If I shipped it priority mail it would probably get there. I'll let you know what the extra is.
