- Thread starter
- #641
I am all set to order one of these carbs from you I hear great things about them I just have one question to make sure I get the right one...? I have a 1976 2f with a jerry rigged Holley carb on it now (have to squirt gas in it to get started). I don't want to get confused between mechanical linkage type and throttle cable type. I think my set up is stock but not sure 100%..? I have a cable running from my pedal to a bent up jerry-rigged bracket on the carb. I was not sure if mechanical linkage meant just near the carb or all the way from the pedal...? If you could please let me know which one fits my needs I would be grateful. I am hoping to order it ASAP! My rid is de-smogged and I've no intention of smogging it again I am in a rural county where I don't have to smog it for tags. Also run a Pertronix Electronic Ignition. Thanks in advance. Any way to call you?
Your cruiser originally had mechanical linkages. Which means there were arms and levers that moved the throttle. Someone has taken all that out and gone to a cable setup. So now you will need to order the cable setup as well probably get a new throttle cable. Get one that is listed in the first post of this thread.
s. Drove to southern Utah for thanksgiving with only minor adjustments. Ran great and I was getting better gas mileage than before
D'oh One day too late! What could I do to get in line for the next batch?
