New 40
Northern Virginia
I'll use this as my introduction and then ask for a bit of help. I lurked here for longer than I care to admit and then in late November picked up this '77 from another MUD member. Work travel and holiday travel kept me busy but I'm finally home to enjoy my new baby. As I said, it's a '77 FJ40 and pretty close to bone stock.
On to my question, the first of many I am sure. Can someone help me identify what limited slip diff I've got on my hands? This spare came with the truck. Long story but it currently has 3.70 in the front and 4.11 in the back. I'd prefer 3.70 all the way around. I got quite a few spares with the vehicle that included this 3.70, which I'd like to be able to rebuild and swap in. Anyway, is this worth rebuilding or should I re-gear the standard 4.11 diff already in it to 3.70?
Thanks for the help and glad to be here.
-Jumba
Enjoy driving it for a while before you work on it!
First park it in a heated garage until the rains wash the roads clean in the NOVA area.
Look up the club there in DC also
@Downey would know what LSD that is.
You really look like a happy guy! Congratulations and I fully agree with @rkymtnflyfisher on keeping it off the salty roads and just enjoy it for awhile before jumping into a major rebuild project.
Looks like auburn ... that was my first thought ... did not check to confirm
Seen just a few... the clustered springs in round opening
As mark said ... Downey would 100% know
We usually put them in the front ... air locker rear
One of the oldest methods to preserve blue fishes:
Bleed and wash the fish, then apply salt to the belly cavity and skin..... ask Columbus.
That is a Limited Slip Differential, could be one of the units we remachined for Toyota Landcruiser's, and here's what is sooooo neat about it- - -it is working/engaged all of the time, even before you get to the snow/mud/sand- - -so you normally just drive straight through the gook without having to lock up something else to keep going. This design is not good for rock crawling, but if you are not a rock crawler, I don't agree that anything else is better, especially since there are no highway trade-offs, it's absolutely quiet, you never know it's there.
I am not sure but, I do not believe you can run different ratios in front and back. When in 4 wheel drive , the front would be rolling at a different rate than the rear.
Welcome
It looks like a fairly new 3rd. I’d see how much play there is at the pinion flange by rotating back and forth. If it’s reasonable, I’d pop the rear cover, pull the axles, and throw it in as is.
Before you start pulling things, make sure you’ve got what you need to make it work with a Semi-float axle.
When you install it, take note of the difference between 3.70 & 4.11s. I’ve chosen to swap in 3.70 gears, but most prefer 4.11. With larger tires the 4.11s can be better... in my case I’ve swapped in 3.70s and 33s for a higher ‘overdrive’ when in 4th.
Unless it’s extremely slippery 4wd is out. I’ve been running different ratios for longer than I care to admit. I’ve not engaged 4wd... if I get stuck, I can temporarily engage it till I’ve got traction again... but that’s it.
Thanks for all the input.
Yes, well aware that with different ratios front and back I would be making a costly error by engaging 4WD. As soon as snow (therefor salt because I'm in Virginia) entered the forecast this week the 40 stayed safely parked in the garage. I have a spare 4.11 ring and pinion as well as another spare housing but have decided to go with 3.70 for now. I'll always have the option to go the other way (4.11) in the future if I change my mind. Lots of long and short term projects to keep me busy over the winter. I've got a few minor leaks to take care of like the timing cover and the seal between the C-Box & X-msn. I have parts to do both when I'm ready. Previous owner noticed the X-msn level high and installed the pressure equalizing fix between the two.
A Tuffy console is probably the first and easiest thing I'll do. I want to get the dash lit a little better and move the top mounting point of the seat belts to the roll bar, all easy stuff, but the rear diff will need to happen so that I can put this thing in 4WD if I need to. Eventually I'll need to address some minor rust where the rear inner wheel wells meet the body and some rust due to deformation where the aux tank supports were welded in. This site is just such an amazing resource. Looking forward to being part of the community.
