never ending starting troubles
I've been battling starting issues for the past two years. Every time i think i got it fixed it comes back to bite me in the ass.
1992 FJ80 with just over 200k miles. I've replaced the starter twice. The starter in the truck now is maybe 4 months old. There is a new battery fully charged in it. I cleaned and checked the grounds. I even went as far as to bypass the ignition wiring like some have suggested. Things were going good and truck started everyday for the past 4 months..... till today. no start, just the same old click click click.
I checked all my wiring, nothing has come loose. Truck started fine four days ago and today nothing. Im really getting tired of this. This issue is the main reason i never take the truck wheeling anymore. Im afraid it wont start on me and i'll be stuck out in the middle of nowhere.
Open to any suggestions on what else to check.
So are you saying you already have a "jumper wire" wired from the starter that you can touch on the battery and it still won't start?
Are you sure the jumper wire is connected to the correct wire on the starter?
Unfortunately you can't assume even the newly replaced parts are good. Have you checked voltage on the battery when you are trying to start? Have you tried grounding the battery to the block with a set of jumper cables (bypassing the ground cable)? Is the positive battery cable original? If so, I would also try to bypass with a jumper cable or simply just replace due to it being 23 years old.
my setup is the same as his first diagram using the ST80
Do you have a multimeter or voltmeter? That's all you need to see where the issue is. It could be the relay, the ST80 solenoid or even the fuse. All testable with a volt meter.
i do, but i am electrically stupid. i have a friend who knows electrics coming over this weekend. hopefully it turns out to be something simple i've over looked. Till then other things i can check i will.
This is probably a long shot but I had a jeep once that had a oil leak. It was finding it's way to the starter and would prematurely foul the starter. New starter would last about a year until I figured out what was going on.
oh i got oil leaks but nothing is hitting the starter. its clean and dry.
any chances any of this can be EFI, fusible link or fuel related?
I recommend replacing all near-battery wiring. Grounds grounds grounds was a montra on another forum I was a member not Land Cruiser related. The same applies. Quality grounds solve a miriad of electrical gremlins
The starter circuit on these trucks is very simple.
If the starter solenoid is clicking, then all associated starter logic wiring is good. The power side of the solenoid is connected directly to the positive terminal of the battery, there is an external wire from the load side of the solenoid that feeds the starter motor, and the starter motor is grounded through the mounting to the bell housing. That's all there is.
If the solenoid pulls in and there is no attempt to crank, then there is no connection inside the starter between the battery terminal and the motor terminal (most likely cause) or the external motor wire is faulty (unlikely).
This is a common problem even with a relatively new OEM rebuilt starter as I just went through this myself. When the starter gets rebuilt it is important to make sure the contacts are flat to the mating surface of the solenoid plunger. If they're not flat then you'll get very uneven/very fast wear on the contacts which cause the starter to fail over time.
It is also important to lube the plunger shaft/spring with a light grease to prevent it from sticking at temperature extremes.
The rebuild parts are available from Toyota for $25-$30 and the most difficult part is removing/installing the starter.
I personally would try to wire a direct jumper wire from the starter that you can touch to the battery. I have had that for a few years now and MY TRUCK STARTS EVERY TIME.. when before it was intermittent.
Remind me again on the jumper wire. I run a wire off the small black wire connecting to the starter correct? Then just tuck it away and touch it to the positive terminal when needed? Will it start even with the keys out of the ignition ?
that is correct. No, it will not start if the ignition is not in the on position.
I can search for my post where i think i took some pics of which wire to splice.
In fact, mine has worked so well, i just took the wire, pushed it in through the back of the dash and placed a push button where the throttle cable goes in our dashes. So now when i get in, turn the ignition on, push the button and drive. It as started every single time since i have put this wire in place.
It won't fire but it will crank. You're simply bypassing the starter logic. It also means that the starter can fire any time in any gear.
that is correct, with the ignition off, it will turn the starter when you either touch the battery with the jumper wire or push the button (if you have wired that jumper wire into a button), but the truck will not actually start unless the key is in the on position.
