Need transmission advice
I bought a 1968 FJ40 this past fall. Had an FJ 40 34 years ago (I'm 66 now) just for a winter when I needed something to deliver newspapers in rural area during the winter in western N.Y. Last couple years got desire to get another one to work on. I am low on mechanical knowledge but admire those who are able to do this kind of work so I wanted to learn and hopefully end up with a vehicle I and rest of family (wife, kids, grandkids) can enjoy. I do have someone who has done restoration work that said he would work on it and let me help. At this time I'm just starting some research by asking questions, listening and learning.
The FJ has a small block chevy 350 in it. It has what I expect is the original 3 speed transmission. My question: The 3 speed transmission doesn't seem to be enough for higher speeds. Can a different manual transmission be installed that will enable it to run better at higher speeds?
I will include a couple pictures. I plan on installing the hard top instead of the soft top that is on it in the picture. The hard top is in great shape.
I appreciate any help you can give me and look forward to days ahead of what I hope can be accomplished with much help.
Thanks
Three speed or four speed, both 1:1 out the back. You'll need an overdrive of some sort or higher gear ratios in the ring and pinion.
1. What constitutes ‘reasonable ‘ speed for YOU?
2. Do you have any idea what the ambient noise level, road handling and wind resistance would be at that speed?
I ask because the first guy I went through the effort to install a 5 speed for ended up selling the truck because he wasn’t prepared for those answers.
I have made a point of discussing these things with customers up front ever since.
Going 85mph in a 40 is close to "ludicrous speed" (Spaceballs) and I marginally comfortable with it. And yes, it costs a bit to get that speed at a reasonable RPM (<2,000 RPM)
I'm perfectly fine with my OD trans at 65mph.
Good questions.
I think reasonable speed for me is somewhere between 55 and 65. I don't expect to use it as a high speed highway vehicle.
As I was driving it prior to winter setting in when I got up to 50 it just seemed like it needed another gear for it to run with more ease.
The answer to your second question honestly would be no and I'm not sure how I would find those answers.
Additional changes on the vehicle I am contemplating that might address your questions are interior matting (heat shield, carpeting?) on the floor and some material on the ceiling of the hardtop. Possible power steering (if possible).
IMHO, Power steering would be the first thing I would add to a rig that I want drive and enjoy often.
Okay then. Fix the steering and the brakes first, and drive it for a little while. Chances are the v8 has enough power for your platform as-is. That being the case, my vote is for an H42 four speed and 3:70 diffs.
Great! Looks like I can start making a priority list. Any recommendations as to suppliers of those parts when I begin to proceed with the build?
Roger, as the others have indicated you need to determine where it is you actually want to be in the end and how much money you're willing to spend to get there. I ran around with a 350 and factory 3 spd from the mid 80's until 2014 before I decided to move to an overdrive transmission to lower the engine RPM at higher freeway speeds. Anything is doable if you really want to do it, it's just a matter of time, money and desire.
Once you come up with your plan it's just a matter of laying out the steps to get there and dig in. Good luck with your project.
Roger
As @Byron indicated, a little better vision of your goals will help greatly with advice. For example, I don’t mind rebuilding stock steering boxes, but if you think you’re going to go over 33 inches tall or 10.5 wide with tires, I don’t advise it.
Another transmission question.
Would the H42 4 speed connect to my present, original transfer case?
Yes. That info is heavily covered in the FAQ section.
I have 2 standard rebuilt H42 transmissions on the shelf as well as 10 conversion kits for the t-case.
Also have this, which needs no adapter:
For Sale - HD H42 Trans,rebuilt, SoCal
