To PNWScooby. Is the 255/85 ST Maxx's OD, mounted on your rims, is 32.8 as show on the Cooper tire spec sheet ?
@PNWScooby
I would really appreciate an answe
i think im going to order a wheel vintigue in a 15x7 and see if it will fit my 40. i would go a 16" but im running new tires and for the 63 bucks its a great price. anybody try these in a 15" yet. thanks scott
View attachment 886639 View attachment 886642 View attachment 886641 View attachment 886639 View attachment 886639 View attachment 886639 View attachment 886639 Received the 16x7 Summit wheels a day early. The wheel shipment boxing was well done, wheels are in a light gray primer. The fit was as to be expected, perfect (a little worried). The 4" BS really left me with plenty of space with the 62 calipers so I think the 3.5" if I could of got them in that would of been fin also. "0" offset, so they sit wheel on the hub. The steering knuckle arm is now within the wheel area but with 1/2 - 3/4 between the rim edge and arm end, plenty of room. It has no cut vents around the inside of the rim mid area you find on the stock Toyota wheels giving this rim a nice smooth look all around the inside. The welds as seen in the photo is a bit rough (not flowing) but not giving any concerns to any brake/axle items. If wanted one can grind the weld a bit smoother being cautious not to take to much off.
The lug ring on the inside rises the rim out from the flushness of the hub about 3/16 give or take. This is seen in many rims types.
All in all this wheel from Summit Racing seems to be a very good candidate for the replacement of the clip type Land Cruiser wheels. I am not to sure but it may even be a possibility to attaché some after market clips for hubs, VW may work. I know summit sells a moon rim for this wheel. Myself I like them without. Tomorrow off to the powder coat folks then to the tire shop then I will post the end results with plenty of pictures.
I am not to sure about the wheels I have if they can except some type of clips for a FJ40/55. As I said I had sold my hubs caps and have no way of being able to reference if LC hub caps will work on this wheel or not. I know they sell what looks like a baby moon hub cap for the wheel from the on line Summit store and Vintiques web site. If you have a LC hub cap and measure the inside lip I can measure the hub ring on this wheel and get a general idea if a hub can work. If you look at Scrapdaddys center wheel ring and then the one I have they are a bit different.
If only Toyota would of made a 16x7 wheel with clips.
If you go to Vintiques web site and looked at the 65-62 or 26 series of wheels they are very close to a wheel that will possibly except the clips that have the Chevy type slant clip pads. Unfortunately they are not made in 16x7
but if you contact them to see if they would make a 16x7 in that series, but I am sure that were the dollars start to add up. There are many other wheel shops on line that can most likely help in that area also.
What a beauty of a truck. The wheels look great.I didn't forget.... my troopy got stuck in customs for months. But here it is now with the wheel vintique 16x7's 4" backspace. fits good! Tires are 255/85 Left them the bare primer they come in for now. Maybe go a darker grey soon. Like the factory split wheel color that comes on 70 series.
So stoked to have a different wheel than most and it fits without spacers !
View attachment 1419327 View attachment 1419328 View attachment 1419329 View attachment 1419330
Pete, thanks for the info. I have the original 16" splits and want to keep the same look. Glad to know
that the 4" backspace will work.
Ken
Tom, I actually have a 1981 BJ42 completely stock with the split rims. From what Pete and others have said on this thread, the Wheel Vintiques 670604 rims with the 4" backspace will fit an FJ/BJ40 without any problem.Ken,
I'm thinking the same tire size for my 77 BJ40 with no lift and stock suspension. The issue I found is not really the tires that are about the 31.5", but the backspacing on the rims. I was told everywhere that I need a negative offset rim (i.e. backspace is less than 1/2 of rim width). Very hard to find those, especially here in Africa.
What year is your FJ40?
Tom
TugWheel vintique series 12 15 x 7 with hubcap , what do you guys think View attachment 1352290
