Need Help Diagnosis
http://www.walmart.com/ip/Sound-Around-Pyle-PDMT38-Digital-Lcd-Ac-Resistance-Multimeter/36264840
A tool to add to your arsenal. The link listed above by @tacosupreme is what I was thinking of for the 3FE. Follow the list.
The multimeter is about $25 from Walmart.
This is under the fuses and relay box thingy...all kinds of crappy looking stuff going on with these wires.
I'm concerned on what these green wires are. I see bare wires. Something has been added or modified, but I don't know if they got messed with during the issue. However, your problems started when it was raining heavy. Water and electrical don't mix.
Pictures are GREAT! Keep them coming!
The coil is not providing any spark to the distributor. No fire, no flame. I'll bet you a six pack of fancy imported beer that the "mystery cleaner" has nothing to do with why the coil isn't firing. My guess would be it's electrical in nature, and might be as simple as a loose ground.
Don't get my hopes up!! Did you see the photo I posted of the wiring behind the coil?
Takes a couple pics of the distributor and the cap. Did he remove the distributor cap when he did the wires? If you don't know, we're going deeper.
That yellow connector is blackened too. I've been feeling around everywhere trying to find anything loose or altered looking.
This is a "new" looking thing. I don't know what it is or what it is attached to. It is threaded inside. On the other side of this piece is where the a/c belt is.
This item is an air conditioning service port that the cap has been removed. Not an issue in vehicle operation. (threaded "pipe")
Yeah, that fuse block is not supposed to be loose.
Pull those wires up and see what connectors they lead to. It could be for an aftermarket stereo, an alarm, or some accessory lighting or something. Either way, bare wires are not a good thing. May need to re-crimp the electrical connector and tape the wires up to makre sure they don't short out.
A better photo of those wires and I'm holding what one of the green wires go to.
Previous owners had the lights, and a stereo in, but were removed. A lot of wiring has been replaced, most of it taped really well. And a lot needs to be just by my opinion as how it looks. That has been intimidating to me. I'm usually busting ass 24/7 and can't afford down time to work on her unless its bad. Like now.
BINGO!!!!!!
WE HAVE A WINNER!
That is the EFI relay! Make sure the wires are no going where they should not be. Someone has jumpered this for some reason. Now we have to figure out why.
Get out your FSM and confirm this in he EWD (Electrical Wiring Diagram) section. It should identify what relays are what. Trace the wires in the diagram to see where they should be going.
I am guessing someone wanted a source for ignition on power, but off when ignition was off, so they tapped into the EFI circuit. That hot wire toughing the metal in a rain storm would make it short out and shut off. Check the EFI fuse. (Do you have a lid for the fuse box?) It would not surprise me to see that fuse blown.
That little guy in your fingers is the EFI relay. That is most certainly a problem, if not THE problem. I need to dig around and find a wiring schematic unless someone has one handy. Once we get it running again you need to bolt the box down and make sure it's waterproof.
What is that yellow plastic connector attached to just under the fuse box? Is seems that the new (green) wire is connected to the Burgundy/Yellow Stripe wire? It then looks like the green wire runs under the fuse box and through the firewall. Maybe the remote on for the PO stereo/amp.
Ok the relay (from the factory) had four wires going to it. Red, and red with a yellow strip on the input side, brown which is a ground wire, and a yellow wire with a red stripe. In theory, you could apply +12V to the yellow wire with a red strip and it would start. Don't do this if you don't feel comfortable with it. In fact just don't do this and see if you can find someone smart on electrical to give you a hand.
Ok. So, let's back up a second. When you try to start your truck do you get a "check engine light" as it's trying to start? Do this right away and report back. Thanks.
All of that wiring is a clusterf#$% and needs to be figured out for sure. At the very least it needs to be cleaned up if not eliminated if not needed.
Its no longer giving a CEL at all. Up until today it came on and stayed on.
My ex-bf put the relay on maybe 2 years ago.
Ok. Well, the EFI relay not coming on is indicating either a) the EFI Relay is bad or b) that wiring is interrupting the circuit.
You need to check all of that wiring and make sure it is crimped properly and wrapped in electrical tape. Or eliminate it if you can trace it properly. Then you need to try starting it again. If still no check engine light then you need to swap out the EFI relay. There are 3-4 of them in the Driver Side kick panel. You can take one from there to try it.
Also check all of the fuses in that engine compartment fuse/relay box.
It w
BINGO!!!!!!
WE HAVE A WINNER!
It was put on years ago tho? Could it just now be causing a problem?
Also, only buy the EFI relay from Toyota. Not the cheap chinese ones from Autozone.
