necessary for clutch install
East Vancouver, BC
wondering if it's necessary to remove the tranny hump to replace the clutch. this will be my first time dropping the tranny and transfer. got all the parts i think i'll need, looking to dive into it this weekend. if it makes the process a hell of a lot quicker, i'd rather keep the tranny hump on and leave the seats and gas tank where they are. BUT if it's a hell of a lot easier to drop the tranny with the hump off, i wouldn't mind taking a bit more time removing the seats and gas tank. as for the shop the cruiser'll be up off all fours on jackstands, don't have a hoist. don't have a cherry picker.
not needed, but heard it helps.
did mine without removing it. took about a day and half with the flywheel grinding to finish the job.
i'm not so sure you would even need to remove the PS seat and tank.
i would say that if you can remove the hump, to do so. then i don't think you have to mess with the shifters. and it would making lining everything back up on the way in alot easier.
I prefer to remove the hump, doesn't take long and if you have trouble getting the tranny back in you've got a better view of what's going on, besides it's less dirt falling in your eyes.
have done many without removing hump but engine must be dropped can use a tranny jack usuall install for me is about 3 hrs have heard of people taking days everyone has there own way need to remove both shifters and it will pull out good luck
yanking the engine?!?! if i have to remove any more parts i might as well do a frame off restoration
well we decided to go the fsm route and do what they say... kinda glad too, once everything's outta the way it makes it real easy to move around and get a good view of what you're working on. the cruisers are so easy to take apart... just putting it back together takes the time and patience. only hiccup we've run into is my flywheel. just looking at it, it's got tons of little cracks and lots of ridges and scores. i don't know if the machine shop'll be able to do anything about it. it looks like i need a whole new flywheel. hiccups were to be expected though.
Pin_Head said:
The flywheel has "heat checking" and machine shops should be able to deal with it as it is not that unusual. They also need to machine the pressure plate mounting surface the same amount.
Why is that? When the machine shop surfaced my flywheel they removed the pins and surfaced the step in the flywheel to remove any checking and then the outer portion of the flywheel to get the factory step height called out in the FSM.
Yes, that is the pressure plate mounting surface of the flywheel.
Sorry, I miss read your post.
