Hi Mudders, brettwilm here. My 94 FZJ80 hasn't started in two months. I've thrown over $1000 at it, and a crap-load of time and effort, some of which I may not remember the exact details of...I would really appreciate your help.
The problem began immediately after a session when I replaced the distributor o-ring, EGR and PCV hoses, and the air intake hose. Immediately afterword, the truck ran briefly (test drive around the block) but then quit as I slowed approaching a stoplight. Ever since, it cranks nicely but won't start. My initial suspicion is that I caused a short in a wire somewhere.
Since then, I've replaced my spark plugs, wires, distributor cap and rotor. I've replaced the ignition coil with no effect. I've replace the VAF / air flow meter. I've tested the EFI relay and associated fuses. I've tested the ignition fuses under the control panel. I've successfully actuated the fuel pump using the test connector. I've had a trickle charger on my battery, which shows over 12 volts on a multi-meter and is only about six months old. I've adjusted the ignition timing.
At start, I have a CEL. When I do an OBD I pull, I get a code 1 "normal."
I was loathe to start a new thread without doing my due diligence. I've run the emergency troubleshooting procedures in the FAQ, and investigated the following threads.
Anything else to try before replacing ECM? Help in northern New Mexico?
Think I killed my ECU, help!!!!!
Intermittent problem getting power to my ECU. Need some ideas.
Bad ECU?
No Fuel = dead ECU. Brother, can you spare an ECU?
I haven't found the fix, although I'm sure I haven't exhaustively tried everything therein. Oh yeah...I had the truck towed to the dealership where it sat for three days and $500 of shop time, and they concluded I needed a new ECM. I don't think that is the right answer (although I haven't tried swapping one).
I do have the 1996 FSM brought to me by BirfMark via ElPolloBlanco, and also bits of a 1994 FSM I have been assembling with Adobe Acrobat, and *gasp* the Haynes Repair Manual for 1980-1996 Cruisers.
Bad ECU?
