Mysterious Starting Problem - Ideas???
NOVA
Website
www.flickr.com
All -
This is by no means a common theme with my truck, it has now happened twice (counting this morning's event) and I am just curious as to any ideas.
Background - Stock 1997 FZJ80, 104,000 miles, Collectors, and the only work I have done thus far is add 285 BFGs and an Alpine deck.
Having said that, twice now upon starting the vehicle the A/T Oil Temp warning light, e-brake warning light, oil level warning light and Airbag warning light will stay on. I will turn the key to the off position and the warning lights will go off; however (and here is the kicker) the starter will continue to fire until I turn the key back to on. And when I mean the starter will continue to fire it will continue to fire until I either un-hook the battery or turn the car back on. I will usually have to cycle through turning the vehicle back on and off until the starter ceases to fire and the warning lights remain off. Once the vehicle is back on there have been no issues as far as driveability or electric.
I have checked all fuses, looked at most of the accesible wires for obvious signs of a short or cut/rub/etc. and I have found absolutely nothing. I am at a loss as to what is happening. The only other "symptom" I have noticed is once (earlier this week) I tried to start the truck and nothing happened for several turns of the key: the only thing that happened was the electronics came on - but the starter failed to fire. I removed the key and attempted a re-start and everything went as it should.
Any ideas would be appreciated. I am thinking of replacing the starter as I think there may be something wrong with it internally that is causing some sort of a "spike" or "surge" through the electrical system.
Thanks in advance for your comments.
You need to replace the starter contacts before they weld themselves together, catch on fire, and burn the truck down. Search for "starter contacts" and all your questions will be answered.
yep...starter is stuck on.
Thanks for the idea. I will order some new contacts from CDan.
In the meantime, limit your driving to necessary trips and carry a BFH with you in case it hangs again. You can pound on the starter and that might un-stick the plunger. We had 1 member that nearly burned up his truck and his home so don't postpone this repair. Your truck is tapping you on the shoulder and asking you to "fix it."
There are several good write-ups on replacing the starter contacts. I'm certain there will be one in the FAQ as this is a common DIY repair at this mileage. The contacts and plunger will be ~$25 from C-Dan.
-B-
All -
Yup, just happened to me this morning. All electronics came on and stayed on once it started. Tried shutting down and starter kept whirring and trying to start. Opened hood and disconnected battery. 1996 w/ 158k. Next!
Yup, I had to quickly disconnect my battery to keep from burning anything up, it was a frantic minute or two...
Just happened to me today for the second time. Calling CDan tomorrow.
THANK GOD FOR IH8MUD! and Woody too!:flipoff2:
I still cannot get it. Disconnecting of battery will helps and it is understandable. But how switch ignition back to “ON” position can “unstuck” stuck solenoid in starter?!? I recon it is something else – possibly malfunction of immobilization system? Very weird problem indeed.
Huh? the plunger literally sticks to the contacts in this case...the current flows through, loads up the electronics and throws the lights as the error code.
Not sure what you are talking about KSV, but if you have a starter that turns over, engine starts, then it keeps cranking...you are going to have a fire unless you replace the contacts and plunger.
Nuff said...unless you are talking about a diesel...then you are completely in the wrong thread :)
OP says "And when I mean the starter will continue to fire it will continue to fire until I either un-hook the battery or turn the car back on". I found it very strange to unstuck plunger by merely turning car back on. I recon if it stuck then there would be only one way to stop it and it is dissconnect battery.
Cheers
