Build My Tucson 40's
Thanks for all the info. I went searching and pretty much the b pillar tube is not going into the tub far enough. The shaped part of the b pillar is not connected to the b pillar hoop. Others have had this problem. Very simple solution.
I am curious how high the b pillar hoop is on the oem bows? Maybe a measurement from the floor up?
Dark and hard to get to!! Tub up height second pic.
Took this earlier this year.
This why I asked about the metal pieces being welded to B bow. I have never compared but believe the tube extends the same on the soft top bow and hard top is the same length.
The left rear side of 73 much have backed it to something or been hit there. Have a small Ridge on the outside where the top of the wheel well is. The bolts on the strap at the top of the snapped right at the tub. Thought maybe the bolts were rusted but after owning for over twenty-five years I removed them. Left hand drill came right out.
The factory bows really impressed be how stout they are. Planning on being in town for a week or two at the end of the month. But figure you be past the point of changing out the bracket at the back wheel well by then. Or measuring the B pillar bow.
Hard to believe this is the same truck as the first post, you are doing a phenomenal job brining this thing back to life.
My repop soft top bows showed up today. I installed them and the doors as soon as I got home. It seems decent so far, but needs some adjusting. The b pillar is way too high. The legs need to be shorter as they are bottoming out in the tub. I love cutting up new parts......lol
View attachment 3052134View attachment 3052136View attachment 3052138View attachment 3052139
I suddenly realize that my 40 tub used to have a soft top. Got holes there for it and everything.
From the mid sixties thru the mid seventies hard top models were made to except a factory soft top. Besides having a tailgate thru the 73 model at least a FST will have threaded holes on both ends of the dash for the eyebolts for the safety straps. 72-74 are even more confusing as all models have footman loops in the rear corners and place for a Vader light to the right of the glovebox door.
The pictures I previously posted are of my 68 FJ40 that is a hard top model. Only holes I had to drill were for the twists along the top of the tub. The factory that were there are different than the one the aftermarket Kayline top required. If Kayline had used the same hole location no mods would have been needed.
I have holes already where the twists would go. Wondered what those were.
So fresh and so clean
Got home from camping up north at Blue Ridge Reservoir and my new seat belts were waiting for me. So was the heat......went from rain and 64 to 110 and oven like. Anyways, I clipped the new belts in place and gave them a try. Good fitment. I used the factory eyelets.
I should be getting some needed parts this week to wrap up the last things. Then it's time to see if it will run. :hillbilly:
