My Tranny update thread
...It takes some serious pressure to move the juice thru all that little tiny tube.
Not true. The ATF moves through the lines and cooler at pretty low pressure. As Cruiserdrew suggests, you really need to do a flow test. At 2,000 rpm you should get about a gallon a minute. The ATF pumps out of the sump, through the guts of the VB, transmission and TC, and then out the outlet and on to the radiator and cooler. So you can open the fluid circuit at various points and then measure flow rate. As long as you keep the sump halfways filled, you should pump out fluid. So first try breaking into the circuit at the outlet of the transmission, then the outlet of the radiator, then the outlet of the cooler. If there's any blockage in the system that should pinpoint it. You may have to add ATF through the filler tube as you're running the motor for 60 secs at a time, but you don't have to exactly match the outflow as you're only pumping out a gallon total. It helps to dump the fluid outflow into a clean 5 gal bucket (reduces spills and that "ATF mess"), then when the minute is up pour what's in the bucket into a gallon container or measure in some other way.
Also, if you're thinking that you can "suck" ATF back into the transmission through the return line, you can't. The intake for the oil pump is in the bottom of the sump and the fluid that's run through the cooler just dumps back into the sump. So there's no negative pressure in the return lines. All the fluid flow through the radiator and cooler is from the small positive pressure on the outlet side.
Come to Phoenix. We'll get her figger'd out.
Thnaks for the offer...If I thought I could make it I would gladly take you up on the offer...
Guess I will be going to Autozone and buying some more fluid and a bucket...
After reading this, I have noticed inside the car where the auto box is, it's pretty darn warm, where are you taking the temp from? I have in infra red temp gauge and can point it at anywhere on the box to get a temp reading, what temp should it run at ?
A warm transmission tunnel is normal. I'm measuring my fluid temperature where it comes out of the tranny to go to the cooler with a kit from Rodney and I think that's what the thread starter has. On a warm day (UK warm! so about 30 deg C ambient) working really hard in low (so not much air flow) I can get my fluid up to 100 deg C and once saw 110.
Tommorow should be the day...gonna find me a bucket and more fluid today....wish me luck...
The hottest temp that I saw here in Panamá ( really hot day means more than 34°C ) are around 190°F for my A442 ..
Ok another question for the powers that be....does the truck need to be in gear and at 2000 rpm to test flow?? of park and 2000rpms???
It doesn't need to be in gear to pump fluid, the tranny oil pump is powered with just the engine running and in that state fluid is pumped through the cooler circuit the same as if it's in gear.
I was able to make plenty of mess at tickover but I wasn't trying to quantify the flow beyond 'yep loads there' and 'nope nothing there'. 2000rpm must be really messy :D
With your symptom being a cold cooler then I'm pretty sure you will also have the same yes or no flow. A reduced amount of fluid flow would still warm the cooler up I think.
Okay.....update time....looks like the hard line is stuffed with crap of some sort....
The tranny flows close to a gallon in a minute when I hook a line up right out of the tranny...when I hook up the hard line to the union and check for flow out front before it goes into the radiator, nothing.
So what should I use to replace the hard lines with???
Thanks guys...
Thanks guys...
Howdy! Sound like you've located the problem. I would be real tempted to shove wire thru that hard line to see what is blocking it. Rubber, Steel, Animal, Vegtable, Mineral?? since you have not found any damage to the outside of it. If you get it cleared, then re-use it. John
guess i can give it another shot...didn't have much luck last time though...
Maybe someone else has experience of using a none OEM hose to fix this but in your shoes I'd take a deep breath and remove the hard lines with a view to replacing them with OEM. You might need to un-bolt the tranny cross member from the chassis and lower it as far as it'll go (watch for stuff on the firewall being crushed as the engine tips back) to get a bit more wiggle room to do this.
At least you're making progress now and know a lot more about automatic transmissions than before :D
I agree with this approach but I would make a good effort with compressed air and a wire to clear the line first. Just the soft lines are $75 each, so the hard lines must be scary expensive.
Are you sure the line that flows through the radiator isn't where the plug is?
I would take out all of the components at one time to limit the confusion, blow them out and localize precisely where it's blocked. You may find some tiny piece of crud in a critical spot and solve your problem for free.
I will look into the cleaning process...I have pushed air through the hard lines before and all seemed fine...I tried some wire today, both from front and from the tranny...no go..too many bends and too much force needed...guess they are coming out...
I am gonna need to remove them If I have any hope of fishing out the clog...
I am sure that there is a clog in the hard line line that leaves the tranny..I get no flow from that line if I push fluid through it while still attached at the tranny..
I get no flow through the aux cooler if I use rubber hose hooked up directly to the output of the tranny...so that is clogged also...will have to figure some way to clean that as well..
All I know now is that the tranny seems to pump good when not attached to the hard line...so out com ethe hard lines...that looks like a really good time...:cheers::cheers:
Sorry if I missed this in your other threads but do you know if your 80 has had tranny work before? Just wondering if a previous failure has filled your cooler with clutch plate paste. No insult intended but are you 100% sure you're checking the right hard line at the cooler end for flow before you remove them? Seems really bad luck that the hard line and cooler are both blocked.
No I am not ever a 100% sure of any thing but am under the impression that the front line out of the tranny is the out side and believe the top hard line is also the out....
I am gonna try and find some different wire today and try again to push it through the hard line before I take them out...as for the cooler will just remove it and try pushing air through it again...
Thanks again guys...
Of course once you get the hard lines clear you could TEMPORARILY bypass the external cooler and just rely on the lower section in the radiator for cooling. That's the way FJ62's are.
But if there's truly stuff blocking the hard lines and cooler, you should seriously consider further investigation. Like dropping the tranny pan and seeing what's in there. There are magnets that accumulate ferrous residue and there's a screen that acts as a filter for the sump pickup. If you're getting junk in the system that is large enough to block the hard lines I'm surprised the transmission is running as well as it appears.
tips for clearing out your cooler/lines
Disconnect the hard lines, plug up the holes in the tranny. Spray carb cleaner into the hard lines in the opposite direction of ATF flow. Follow with compressed air. Lather, rinse, repeat. After you clear the clog, run some brakleen through it and blow that out.
Next, completely remove the aux cooler. Lay it on a bench. Fill it with carb cleaner through both openings. Let stand. Blow it out over a drain pan. (Wear safety glasses. You will get it in your face. :) Lather, rinse, repeat until the clog is cleared up. Then run Brakleen through it and blow that out. Make sure all of the Brakleen is out of it before reinstalling.
If that works (and it prolly will) you're $$$ ahead. If it doesn't, you're only out the cost of a few cans of cleaner.
Either way, drop the pan and clean it, the magnet (assuming it's even still there) and the filter screen. Refill with ATF, test drive and enjoy.
Ok...new update..I have given up removing the hard lines...I am just gonna cut them...then remove them clean and then splice them back together with some good quality rubber...I like the idea of the brakecleaner and will give it a shot...cause when I push air through it works fine..
As for dropping the pan...Will do that if and when I get the lines clear...I dropped it maybe 100 miles ago and the pan had some residue but nothing big enough to clog lnes or enough to scare me..
