My Tranny update thread
A balanced city
If anyone was folling my saga or is interested...I will post the inks to all the prior threads..Basically I have a 94 that has a hot tranny :frown::frown:
I have done so much with it I am just giving up. The tranny runs cool or cool enough on the freeway, under 210 but on surface streets it heats up to uncomforatble temps..like above 240...I have removed the pan, removed the unions swaped hoses to clear and still no fluid flow to the coolers on a consistent basis.The coolers are always cold both the one in teh radiator an dteh aux out front. Truck shifts fine and drives great.
I am at a loss quess it is time to just take it to a tranny shop and see what the output pressue is..any ideas are always welcome..
https://forum.ih8mud.com/80-series-tech/229045-hot-tranny-94-a.html
IH8MUD™ Forums
https://forum.ih8mud.com/80-series-tech/232112-hot-tranny-94-final-update-till-blows.html
https://forum.ih8mud.com/80-series-tech/232277-inline-tranny-fluid-pump.html
Howdy! Have you checked all the lines for damage/obstructioins? Can you drop the lines and blow air thru them to see if you get any flow? Try plumbing in just one cooler at a time to see if either one cools/heats more than the other. Maybe you've got a crimp or a plug in there. John
Howdy! Have you checked all the lines for damage/obstructioins? yes several times and am geting good at it :frown:
Nope no crimp and yes I can push air through...get some fluid but no real flow...
Anybody have an opinion about s*** caning the hard lines?? That way I can use the unions and stubs to adapt to the tranny...
The last test that I should do it's unplug the hard lines direct from the tranny body and start the cruiser ..
I have and fluid comes right out of the front hole when I start the truck...
I still think you haven't proved you even have a problem. Go see the tranny shop, if there's anything even thinking about being wrong with it, they'll point it out.
-Spike
Spike, does your aux cooler get warm to the touch after driving?? because mine dosent
I am gonna take it to a tranny shop again, this time a different one but need to find someone that at least appears to know something about Toyota trannys first..
let me know when you found this guy .. I will take my tranny cooler and see if it's hot to the touch when my tranny temp gauge get the 160F temp ..
I'd bet spike's is 150° just sitting in his driveway with the engine off. Mine is.
Howdy! Might just have a shop do a flush/fill service on it to see if that cleans it out. If the coolers are not heating up, then you don't have much/any fluid moving thru them. It takes some serious pressure to move the juice thru all that little tiny tube. John
That is what I did after I put in my Rodney special. I might get to 180*-185* if I am on surface streets for a long time. On the freeway at 70 mph it might start getting up to 165*.
I would try running with list a stub out of the high pressure side to see how much fluid you are pushing, and how fast it come out.
Any body against blowing air back up the high pressure line into the tranny to try and try to unblock it?
Good luck.
I am ouuta town right now and wont get to do anything with it for week or so...but looking to s***can the hard lines...using the unions that come outta the tranny and back in as adaptor to the soft lines. I think a tranny flush and fill might also be in order....cause I REALLY want to drive the truck and get moving forward on other projects..that I am sick of the taste of ATF in my mouth ;p;p
Yesterday I touch my tranny cooler ( front in the same place of the factory but mine it's a B&M ) and only can keep my fingers on it for about 5 segs when my gauge was reading 170F ( same place as factory dumb light factory bulb ) and my engine was running too ..
I did not read your old threads, but did you do the Rodney flow test? I would check for flow at each point in the lines. It should be about 1 gallon per minute at 2000 RPM. On my FJ62 I had 1 gallon in 45 seconds which I assume is normal and that's at the outflow of the radiator fitting. Once you find where it doesn't flow, you have found the problem and can just replace. If the pump was bad, the whole tranny should not work.
The other option is to just re-plumb the cooling and eliminate everything but the hard lines and run a new, large auxillary cooler. 240 degrees sounds very hot. If I had to *guess* I'd say the rubber in your soft lines has deteriorated and collapsed or the line through the radiator is blocked. There isn't much else.
I would also suspect the rubber lines but they have been swapped out....and the radiator is new..
I get good flow out of the out put of the tranny but beyond that there is limited flow..I get good air pressure through both lines when I remove them from both the tranny and coller sides...
I think I am just going to remove the hard lines from the equation and see what happens..But to do that I have to chop them up...Will try and work on it some Thursday and Friday this week...will let you all know what I find...
Thanks and any other ideas shoot...
I've been through something similar to this last year. In my case the problem was the cooler in the bottom of my month old radiator had somehow become blocked after working fine to begin with. I ended up adding another aux cooler and bypassed the in radiator cooler.
Your aux cooler should definately be hot, uncomfortable to hold, when the tranny is hot.
Disconnect the hard lines at the cooler end, where the rubber pipes go to the cooler, one at a time and get a bucket :D while someone runs the car for a few seconds. One of the lines should be the output from the tranny and shoot out, the other is the return and won't. If one of them gives good flow you probably just have a blocked cooler, bypass them one at a time till you find the culprit.
What you've described doesn't sound like the hard lines to me and I think if you remove them you're just banking some trouble for a later date.
Is your torque converter lockup working? I'd guess not if you have no cooler flow.
Thanks for the input...torque convertor seem to work cause it runs cooler on the frewway...rpms drop when I get it up to speed.. guess I will give it another shot on Thursday...Just wish I could beat it..
When I had my problems last year the TC lockup also failed and I had a new TC off Rodney. I sent him my old TC for diagnosis and he said the lockup friction material was broken up and gone.
AFAIK fluid goes through the TC lock up circuit then out to the cooler and blockages in the cooler circuit reduce flow in the TC lockup and can lead to insufficient pressure letting the lockup plate slip.
We never conclusively determined if my cooler blocked first and that killed the TC, or the TC friction material failed first (this was about 18 months after a rebuild and they may have used substandard materials) and blocked the cooler but I'd avoid lockup speeds till you have this solved. Taking the tranny out to change the TC had not been in my plans!
Edit:
I went back and read through your previous threads - sounds like you have already had good flow from a disconnected output hard line at the front. Also sounds like you've never bypassed the in radiator cooler because it's new?
Only some of the fluid the oil pump pumps goes through the cooler circuit so a normaly shifting truck would be expected with your symptoms. AFAIK that fluid is from the TC lockup circuit and when the lockup is engaged nothing flows and this is the only time your cooler should go cold - during TC lockup.
Jon,
I have tried bypassing both coolers and as a matter of fact right now the one in the radiator is bypassed.
On Thursday assuming all goes well I am going to try and push fluid through all the lines and see what I can see. I will start by disconecting the soft line that goes into the radiator to see what kind of flow I get there...then assuming I get good flow will disconnect the output of the radiator after reconnecting the input.
I guess what really bothers me is that the truck shifts and drives so good it is hard for me to believe that the tranny is bad:hhmm::hhmm:
I have had a couple of buddies drive the truck and they all agree it shifts and drives good...
Good luck with the checks, sounds like you haven't killed it yet and just need to track down the blockage :) BTW, you shouldn't need to put the tranny in gear, just having the engine running powers the tranny oil pump and pushes fluid through the cooler circuit.
