My Single Circuit Brake UpGrade
landcrusher909
Athlete/Race truck driver/Hobbyist
GOLD Star
Southern Calif.
It was time to upgrade the brakes on our 1967 FJ 45 LWB, I have been kicking around the idea of making our own adapter and after talking to a buddy :hhmm: ( Cherry Valley Joe ) I expaling what I wanted to do. Use a later FJ40 Duel Circuit Master Cylinder ( Still runnning drum brakes ) and not have to cut the fire wall and still keep the stock air cleaner. Well here is what we came up with.
that looks somewhat similar to what Mark A came up with.
For mounting the Master Cylinder Joe drilled and tapped the adapter and we have a machine fit centering the Master Cylinder on the adapter. As you can see we have no problem clearing the Carb and the stock Air Cleaner. I have a 1974 1F in my 45 so this would also work on the earlier 40's and 45's running the stock motors.
That poor pristine truck.......................whats next a roll cage and tube bumpers..............
I like it!
It's just extraordinary looking at a dual circuit master cylinder all mounted up without a booster though.
Nice work, Rob. When you finally install the booster and 4WD, it will be even better!
nice shorts! :grinpimp:
Shorts???? They look like longs!!! :lol:
I dont know about tube bumpers but I did just order a set of air bags for the rear :flipoff2:
Are you still going to use modified Chevy trailing arms with the airbags and eliminate the rear spring packs?
why do you want to keep the drum brakes?
I am planning on upgrading to disk down the road
I am very interested in how it works for you. FYI, I found this link a few weeks ago..
https://forum.ih8mud.com/40-55-series-tech/456785-brake-master-option-early-fj40.html
Yea I thats a great upgrade, I wanted to make an easy switch and still use the factory Master Cylinder. Today I got everything bolted up had to wait for the wife to get home to bleed the brakes, Ended up making a longer push rod and everything is working great. Tommorow I will be able to get the drive shafts on and everything buttoned up for a test drive :steer: Looking back I remember Mark A. using or posting something up about brake line connectors That would have made plumbing the brake lines alot easier.
Looks great! glad you got it working! I like your adapter did you just use the factory front line and just eliminate the "T" at the right front, and just route the rear line over the fire wall there? I just bought the JT Outfitters Adapter and I aquired a 1971 FJ40 dual M/C so hopefully I will be installing this tonight...but after looking at your pics, it doesn't look like there is alot of room at all for that brake booster. We'll see... other than that I need to buy a few fittings to make sure I have enough for this...I'll let ya know how it goes
JT outfitters toyota M/C adapter
Ok I have figured out that the brake fittings are M9x1.0 so I bought a pack of them, and a union for the front right to separate it from the rear. Got the MC bolted up to the bracket (had to relocate the factory drop in filter to the fender) now I am just working on extending the push rod. Lowes didn't have M10x1.25 all thread so I'll have to weld some nuts&bolts together...
IMG%5F0539
I just re-drilled my firewall to fit the master cylinder when I did mine for my '63, I also didn't use a booster. I didn't have access to a mill at the time, if I was to do it now I'd fire up the Bridgeport 2J I have access to and whittle one out like that. Looks good.
I have been asked lately about the upgrade I did to the 45 almost 9 years ago. I have to say its work out perfect i did upgrade to disk brakes in the front and so far we have logged in thousands of miles with no issues. I have moved on from selling the adapter plates there still available from Georg @orangefj45 at Valley Hybrids.
