Well, after a long day of tacking and welding in my sheet metal on my trailers front box, I am at a cross roads.
I am trying to figure out if I should weld up my sheet metal, or rivet it onto the tube frame.
Pro's of welding:
1.Faster than the riveting.
2. Cleaner look than the rivets, easier to paint and prep.
3. I don't have to buy a kerbillion rivets.
Con's of welding:
1. It is too cold to get my weld through primer to set up correctly.
2. Instructions call for 70*, and there is no way I can get my garage that warm, and my test piece failed miserably and came out a mess.
3. Can't get any rust proofing between the panels since its too cold to prime.
4. Controling the heat and warping issues.
Pro's of Riveting:
1. I can use Sikaflex and rivets and get a super strong, water-tight bond.
2. Easy, and I don't have to worry about warpage.
3. Easier to readjust/repair/modify down the road.
Con's of Riveting:
1. I loose the smooth look of the welded steel.
2. I have drill about a gazillion holes.
3. I have to buy about a gazillion rivets.
4. Could be messy with the adhesive/sealant.
I am open to your thoughts... fire away!
Thanks!
