Build My R2.8 Cummins FJ40 (RJ40) daily driver build
Ok this next one I'm going to catch some flak for sure.. so let me explain myself haha
For the seating I wanted a few things:
1) enough leg room for me (I'm 6'5" and all legs)
2) comfortable power seats for front with heaters
3) comfortable, front facing, heated, removable seats in the back.
In order to get comfortable seats in the back that were easily removable I did something weird. Instead of finding a bench I put in a single captain chair from a 2005 Honda Odyssey. I'll get it re-upholstered to match my front seats and put in heaters. So I've got a 3 seater car... Very strange. Maybe I could've found a way to do a double back seat, but the mods are done, so there's no going back
And now I'm working on getting my mounts built for my engine and crossmember. Should be done soon. They won't be as nice looking as yours @amico... unfortunately
Hey if they are bolt in motor mounts you are fabing then Eastwood sells a pretty cheap powder coating kit (I think I paid like $200 for mine). Then get you a used electric oven for $50 bucks and you'll be golden.
Has anyone used Polythane body mounts? I've heard they squeak. Any experience out there?
Still waiting on my Hydra-tech booster. Should get any day now. But finally got my air cleaner setup figured out and installed. Seems like everything hast to be custom fabricated.
Haha yeah! Everything takes so long to get done
Rear suspension is in and I found out I'm going to have an issue with my front drive shaft clearance and my oil pan.. I'm ordering an aluminum pan so i can section out the problem area. Major bummer but at least there's a solution. I should've mounted my engine closer to the driver side.
I couldn't find anything cheaper than the Torfab manifold for my AC compressor. That sucked too. $140. At least it's cheaper than Axis.
Anyway. Here are some update pictures.
